Brakes pull to the right??
Old Sep 12, 2013 | 09:18 PM
Dartster 66's Avatar
Talking Brakes pull to the right??
It is a 2003 Dodge Stratus Gt
I have put new calibers and new drilled and slotted rotors and new brake pads even drained & filled master cylinder but once in a while it will pull to the right ?? Is it possible that the brake proportioning valve is hanging up???
Thank you
Old Sep 13, 2013 | 02:40 AM
I would check the suspension and the steering rack mounts
Old Sep 13, 2013 | 06:58 AM
I Agree !!!
Old Sep 13, 2013 | 08:50 AM
And tire pressure. Swap tires left to right and see if the problem changes. "Wiggle the crap" out of stuff up there looking for looseness
Have someone work the pedal, pump a little out each left/ right bleeder, and "feel" for difference in flow. Line pounded flat by damage?
Old Sep 13, 2013 | 01:46 PM
pro-tech's Avatar
Check the front suspension and lower ball joint. The lower control arm mounts were a problem on these cars. So check that real close...Bill
Twin 440s
Sep 19, 2014 10:14 PM
Marc Greenleaf Jr
Aug 29, 2011 04:47 PM
trev0006
Jun 30, 2011 05:31 AM
cmetzbower
Jun 13, 2011 05:35 PM
dutch207
Apr 27, 2010 04:59 PM
