Brands of parts for 440
Old Mar 4, 2018 | 12:24 PM
Nathan McCormick's Avatar
What's a good brand on gaskets rings and bearings for a 440 also a good brand cam.... and what size would be good for a 440 I want a really low/long lope I'll use a stalled torque converter if needed it's a stock 440 with a thermoquad carb
Old Mar 4, 2018 | 02:27 PM
Archer's Avatar
Nat -
You have a late 70's 440 (good block, but but no compression with those pistons, which makes most "big" cams are a no-no.
Pick compression with new pistons/crank, then optimize cam and intake/exhaust will follow.
I like the TQ, but more for a small block, than a BB (I know they came from the factory that way...)
A Holley or good Eddy would be a better bet.
By the time you get all the new parts and add in machine work, you might be better off saving your bucks and getting a crate motor.
Not as much fum to build, but easier to drive.
Old Mar 4, 2018 | 02:49 PM
I don't wanna do a major rebuild im going to use what I have what would be a big enough cam to use in it to make it sound good also.... and what brands of bearings gaskets and rings should I use
Old Mar 4, 2018 | 05:36 PM
Here is a cam and kit is as big as I would go.
https://www.summitracing.com/parts/c...23-4/overview/ it says you can use a stock converter but......
Here is on I think would perform better with a stock 440.
https://www.summitracing.com/parts/c...22-4/overview/
get a full kit with springs etc and a good timing chain.
Summit can help you with other parts.
look at 440soures.com also, I would recommend a book on performance builds of the 440.
moparwannabe
Sep 9, 2013 08:50 PM
73_Duster
Jul 10, 2011 10:07 PM
dodge6890
Apr 28, 2011 04:14 PM
mvanwy02
Apr 15, 2010 05:45 PM
Lstroeh
Sep 30, 2009 02:39 PM
