Camshaft help!!!
Old Jul 31, 2013 | 10:54 AM
nwade2006's Avatar
Camshaft help!!!
I am currently restoring a 75 Dart, and I am putting a stock 360 in it. I am looking for a cam with a little lobe in the idle, but I don't want to change the valves, springs or lifters. Any suggestions would be greatly appreciated.
Old Jul 31, 2013 | 10:57 AM
nwade2006's Avatar
Sorry push rods not lifters. Obviously I will be using new lifters.
Old Jul 31, 2013 | 11:03 AM
Brother Mopar's Avatar
Ive been doing some cam research for a 318 build and playing around with CamQuest(On compcams website-offers a simulated dyno based on features you put in) combined with the advice of the guys who really know their stuff on here has proven invaluable.
Old Jul 31, 2013 | 01:04 PM
Have a look at Whiplash and Thumpr series cams. They are designed for stock engines to give more power and that sound your looking for.
Old Jul 31, 2013 | 01:55 PM
Don't forget to look at Lunati...
http://www.lunatipower.com/
Old Aug 2, 2013 | 08:54 PM
moe7404's Avatar
i put a 1968 4 speed 340 cam in a 1980 360. but had to have the valves guided timed. it has some lift but cant remember. a guess .444 lift. for a daily driver this should be the limit. a low stall 318 converter worked fine. it made lots of power. and used lots of fuel. it was in a 1982 ram club cab 3/4 extra DH. 5,000 lb. but i walked all over a ford deisel truck.
Old Aug 3, 2013 | 08:28 AM
Don't forget that when you get into lumpy cams, You start loosing your lowend and you also start moving the RPM range higher for normal operations....
Now with that said.......
I like Crane Cams..... (Chas) who works at Crane is an Mopar guy.
I like there Classic cams....
mudjunkie
Nov 9, 2021 10:50 AM
Air Bubba
Jan 17, 2013 09:54 AM
woody02
Apr 25, 2012 07:15 PM
Duster360
Feb 14, 2012 10:55 AM
staledog
May 19, 2009 08:29 PM
