charger cluster
Old Apr 14, 2019 | 04:14 PM
bobdodge's Avatar
charger cluster
i have a charger cluster it has 150mph speedo, clock and tach behind clock this cluster does not have the hazard switch there is no opening for it on the left hand side just lights, panel & brake light.
there is a spot for it on the back assembly just not the trim
its a "wood grain" finish. but someone drilled a hole in it for some reason.
my father passed away so im trying to help my mom sell off some stuff. has the wire harness attached to it it shows 08852.1 miles
just trying to figure out year and i take it is a rally cluster
and value thank you
Old Apr 14, 2019 | 05:31 PM
A picture would help identify the part a great deal.
Old Apr 14, 2019 | 05:55 PM
bobdodge's Avatar
No hazard switch
You can see the dang holes below the fuel gauge
Old Apr 16, 2019 | 11:49 AM
bobdodge's Avatar
its a 70 cluster guess ill throw it on eabay and start bidding at $100? this thing is pretty hefty with the wire harness down to the bulkhead. i believe the gauges alone should be qorth atleast that.. trim ring has aluminum cover it could be repaired just dont know if anyone would with all the aftermarket parts out there.
Old Apr 16, 2019 | 12:00 PM
You never know, good luck.
Old Apr 16, 2019 | 04:27 PM
1970 Charger would be correct.... Sounds like a good fair price... Good luck with the sale...Hope it finds a good home...
Old Apr 17, 2019 | 09:46 AM
bobdodge's Avatar
thank you. im not just here to try to get values.. i will contribute and do my best to answer other members questions.
ive been out bulding engines and working on cdpd,s for awhile i currently own a 94 dak and a 66 plymouth sportfury was a wide block car now has
a 1968 crysler tnt 440 with matching 727.
pascualindio
Feb 23, 2020 10:00 AM
rc-ltu
Nov 1, 2012 08:44 AM
Hobbles
Feb 22, 2012 06:42 AM
rc-ltu
Mar 8, 2011 05:29 PM
tealfoster
Mar 10, 2009 07:15 PM
