Code 1004
Old Aug 31, 2021 | 06:00 PM
300awd's Avatar
Code 1004
Are all the manufactures using these damned runner valves now? My 300 3.5 short runner valve flapper is all crudded up and barely turns. Throws a 1004 and I'm going into limp mode. Will this code cause limp mode or should I be looking elsewhere? The only other code is EGR, for years that's been on.
Sorry if I'm in the wrong place. Late, tired, wits end. You know.
Any help greatly appreciated.
Old Sep 1, 2021 | 08:57 AM
is the EGR code a fault? your CEL just been on for years? i know this feel.
Old Sep 2, 2021 | 01:35 PM
Take it off and clean it and install a new o-ring and see if that helps the issue...
When you take it off Pay Close attention at what the angle is of the blade so you can reinstall it at the same position.
Pull and clean the EGR if you can also.... Should show a code of PO404, PO405, PO406, ???
Keep us posted...
mr340
Aug 22, 2018 05:41 AM
jaygr
Oct 24, 2012 02:39 AM
Daniel Albert
Jul 21, 2012 07:22 PM
CantRamItDodgeIt91
Jun 12, 2010 10:43 PM
azcuda
Cuda Specific Discussion
Jul 13, 2009 08:55 PM
