do i have to use a bronze oil drive with a solid roller cam?
Old Jul 5, 2014 | 04:01 PM
maca's Avatar
Hi,
I am installing this comp cam into a 360 magnum. I wanted to know if I need to change my oil pump drive gear for the roller cam? I was told I may need to run a bronze oil pump drive gear as its a solid roller cam.
thanks
http://s1081.photobucket.com/user/ma...G2196.jpg.html
Old Jul 5, 2014 | 04:40 PM
Lists this as a Steel Billet, so Yes.
http://www.compcams.com/Pages/402/ca...spx#raceroller
Old Jul 5, 2014 | 11:24 PM
maca's Avatar
Thanks coronet, Looks like I need to get one.
Does anyone know if the magnums have a hardened gear already or would they be the same as the earlier LA ones
The gear in it now is the factory magnum one as far as I know. I have seen some pics of LA engine ones and they seem to have a pin you can remove to change the gear on the shaft. My magnum one doesn't have that pin. It looks to be all one piece. Not shiny though like bronze.
cheers
Old Jul 6, 2014 | 09:14 AM
Some gears are pressed on and not pinned. I would get a new pinned, hardened intermediate shaft with the gear and install yourself, the preassembled ones look pricey.
maca
Apr 17, 2015 08:02 PM
maca
Feb 21, 2015 05:40 PM
norcalmopar
Aug 6, 2010 03:51 PM
Chuck_S
Jul 10, 2009 09:15 PM
dzltd02
Oct 28, 2008 08:25 AM
