Dodge Ram Sport 5.9L Help!!!
Old Oct 30, 2017 | 03:44 PM
Dodge5.9's Avatar
I'm having two issue's. First off is after starting my truck about 10 -15 minutes I start hearing a faint grinding noise. I also noticed that I can smell coolant but it has no leaks anywhere. I noticed turning the heat on the sound starts getting a little more aggressive. We have just replaced the tensioner, idler pulley and power steering pump. The only two things I cold thing of would be fan clutch or water pump but I'm leaning more towards the water pump. The second problem I'm having is the belt is riding the front of the crank pulley rather then being in the middle of the pulley. We just replaced the belt and have tried adjusting it multiple times. I will include pictures of what I'm talking about as far as the belt. Any info is greatly appreciated. The truck was bought from a dealership with no warranty. It currently has 89k and has been kept up to date mechanically.
Old Oct 30, 2017 | 04:44 PM
I'd think you have an alignment problem with the tensioner maybe a bad new part.
Old Nov 2, 2017 | 02:07 PM
I Agree..... Recheck all the alignments of what was installed... Something is not square....
Old Nov 2, 2017 | 02:44 PM
Dodge5.9's Avatar
Found the issue. The water pump bearing was going out. It also caused my belt to become out of alignment. Thanks
Old Nov 2, 2017 | 07:42 PM
Glad you found your problem, I have been through it with my daughters car.
Old Nov 3, 2017 | 11:20 AM
Good Job.... Glad you got it fixed....
toma1383
Nov 11, 2017 03:48 PM
t/s1148
Apr 29, 2015 11:09 AM
Jayman55
Jun 7, 2012 11:13 AM
bddanford
Aug 18, 2009 12:20 PM
Ekimwood
Mar 15, 2009 04:40 AM
