Drum brakes for 64’ Sport Fury
Old Apr 1, 2020 | 12:02 PM
Codfather's Avatar
Just installed new rear brake shoes and springs. Everything is installed correctly but the drums won’t go back on. The shoes are touching the upper pin, and the adjuster is all the way in. The drums fit with no problem when I remove the adjusters. Also the parking brake is not engaged. I’m at a loss.
Old Apr 3, 2020 | 08:25 AM
Sounds like the wrong size shoes... May have been missed boxed
Old Apr 14, 2020 | 06:02 PM
mapman's Avatar
be sure the e-brake cable has returned all the way. back the adjuster off completely and pull the cable back to see if that helps. Move the shoes up and down against the pins to help center the shoes in the drum.
Rob
deltchief
Apr 17, 2016 10:51 AM
dsikkema
Jul 14, 2014 05:14 PM
CurtRod58
Dec 21, 2012 03:52 PM
breckjar
Sep 28, 2011 09:36 PM
first64dodge880
Sep 28, 2010 10:34 PM
