extra capacity oil filters
Old Feb 17, 2009 | 09:49 PM
johnthegoalie's Avatar
thinkin with me dipstick
hey fellers, found this information that might be helpful.
seems there are a few different filters that can be interchanged (same threads and diameter) i'll check in person to make sure first hand, but here are the fram numbers i found...
ph16 is a 1/2 quart filter
ph8a is a 1 quart filter
ph977a is a 2quart filter
Old Feb 17, 2009 | 11:09 PM
i think all the old mopar engines use the ph8a, my 05 ram calls for the ph16.
Old Feb 18, 2009 | 02:13 AM
Polaradude's Avatar
Here's one ya can try also, You know you can buy that flexible magnetic tape. wrap a strip of it around your oil filter. This will magnetize the oil filter and catch any small metal frags that might be in your oil system and when you change your oil just put the mag tape on the new filter.
Old Feb 18, 2009 | 02:17 AM
That is an old trick Polar.
A lot of the motors (V6s and V8s) from the 70s to now have used the PH16 filter. Thats good to know about the other two though.
Old Feb 18, 2009 | 02:45 AM
Polaradude's Avatar
it's a good one though.
Old Feb 18, 2009 | 04:17 AM
Crazy4Carz.Com's Avatar
Space is the limiting factor. The newer engine bays don't have room for the bigger filters. and be careful if it hangs down and it hits something, what have you gained? The engineers that design these cars get paid millions of dollars a year. I'm not going to try to out guess them. If the bigger filter would fit and was a better choice I don't doubt they would have used it. If on the other hand you are re-deigning a car from the ground up, then use your best choice.
Old Feb 18, 2009 | 05:58 AM
If you have the extra shace though and need/want a little extra oil for some reason then its a good idea.
Old Feb 18, 2009 | 08:13 AM
i have a line on the uber strong round magnets that are used in microwave magnetrons - they fit real nice on the end of an oil filter
Old Feb 18, 2009 | 08:58 AM
Commando's Avatar
John do you have any pics of the magnets you're using?
Old Feb 18, 2009 | 09:05 AM
they are about 2-1/4" diameter
Old Feb 18, 2009 | 09:09 AM
They look like oversized tranny magnets.
Old Feb 18, 2009 | 09:27 AM
72RDRNR's Avatar
never understood why engineers get paid so much when they make you remove washer resivor and wheel well just to change battery. heck just last night I was reading how to change oil in wife's new van, you have to put left hand on nose and right hand on left ear, turn around 3 times then get under van and open 4 access panels to get to filter. I aree with 66, give me something old. one I can stand between fender and motor to work on it!!
Old Feb 18, 2009 | 09:36 AM
Commando's Avatar
Oh ok, that looks like a good idea, and I assume that goes on the end? And the magnetic tape wraps around?
I still have the radiator and fan out, and find myself standing there quite a bit scratching my head trying to figure out what easily accessible part goes on next.
DDAutoParts
Nov 15, 2013 01:16 PM
Dave E
36
Oct 8, 2013 01:22 PM
Jan 18, 2012 07:33 AM
Recoil77
Apr 10, 2011 01:33 PM
dzltd02
Oct 28, 2008 08:25 AM
