Factory undercoating?
Old 05-22-2013 | 03:52 PM
70newport's Avatar
So working away on my rear end I noticed that the "factory undercoating" on my 68 Newport is cracking and peelin off. I don't have time or money for sandblasting so I'm thinking get in there with a brush and scrub away. Whatever falls off is fine ad then I'll use a spray in undercoating.
Is this a terrible idea or what other suggestions does everyone have.
Thanks,
Gary
Old 05-22-2013 | 04:07 PM
That's a great idea, protect what you have. After scrubbing it, I'd wash/clean the area, let it dry and then hit it what an undercoating.
Old 05-22-2013 | 05:23 PM
If you have a power washer? hit it with that first, a lot should come off..
Old 05-22-2013 | 08:32 PM
Buffalojoe426's Avatar
Thanks,
Gary
I had my Charger blasted and found that it did very little removing the undercoat. I found by using an air hammer with a chisel head you could pop most of it off. Just be very easy, Hold the chisel parallel to the body. Just a light squeeze of the trigger. The Under coat flakes off and leaves the body undamaged. A wire brush wheel on a grinder also does a good job but removes a lot of the paint around and under the undercoat.
72Charger
06-21-2018 07:17 PM
camfreak1
01-01-2014 03:47 PM
Marc Greenleaf Jr
08-15-2011 04:57 PM
smackhonda
09-04-2009 08:11 PM
NewportLord
06-20-2009 11:43 AM
Quick Reply: Factory undercoating?
