Factory undercoating?
So working away on my rear end I noticed that the "factory undercoating" on my 68 Newport is cracking and peelin off. I don't have time or money for sandblasting so I'm thinking get in there with a brush and scrub away. Whatever falls off is fine ad then I'll use a spray in undercoating.
Is this a terrible idea or what other suggestions does everyone have.
Thanks,
Gary
Thanks,
Gary
Thanks,
Gary
Thanks,
Gary
I had my Charger blasted and found that it did very little removing the undercoat. I found by using an air hammer with a chisel head you could pop most of it off. Just be very easy, Hold the chisel parallel to the body. Just a light squeeze of the trigger. The Under coat flakes off and leaves the body undamaged. A wire brush wheel on a grinder also does a good job but removes a lot of the paint around and under the undercoat.
Marc Greenleaf Jr
Aug 15, 2011 03:57 PM
