Flashing Lights
Old Apr 17, 2009 | 07:44 PM
sgp7679's Avatar
Question Flashing Lights
My brake and reverse lights aren't working. The night lights work though but just don't light up when you press the brakes. Also when you put the car in reverse the reverse lights don't come on. What could cause this? Some kind of switch? How would I check it?
Old Apr 17, 2009 | 08:02 PM
scotts74birds's Avatar
Sparky to the rescue! Not sure if both of those are on the same fuse, but you've checked that already, right? I'm not thinking ground because the running lamp filament uses the same ground path in the 1157 bulb in the tail lights. You got turn signals working in the rear? That should tell you if the hi-lite filament wire to the rear is working, that and the brake lights share the same wire. I"ll be up for a while, laid off from Chrysler.
Old Apr 17, 2009 | 08:07 PM
sgp7679's Avatar
yep, running lights and turn signals work. The fuses looked ok.
Old Apr 17, 2009 | 08:12 PM
Great. Now we're on to the brake light switch. Dont want to sound condescending, but there are alot of young folks here. Do you know where the brake light switch is?
Old Apr 17, 2009 | 08:31 PM
sgp7679's Avatar
nope, i tried looking for it once bit no luck, where is it?
Old Apr 17, 2009 | 08:39 PM
Well unless they were weird in 65, it should be a small "button" type switch on the brake pedal arm inside the car. Should contact the arm 6-10 inches above the pedal. It would probably have a plastic connector and 2 wires going into it.
Old Apr 17, 2009 | 08:58 PM
sgp7679's Avatar
how do i check if its any good?
Old Apr 17, 2009 | 09:01 PM
If you found it, use your electrical meter. Have one? If not we go to plan "B" Can yahoo im if you want. "Talk to me Goose"! You want to find if you have "continuity " through the switch when its activated.
Old Apr 17, 2009 | 09:56 PM
sgp7679's Avatar
yea i have one around here somewhere. ill check it out tomorrow.
Old Apr 17, 2009 | 10:01 PM
K. Good luck. I'll be around the site tomorrow if I can help with anything.
Old Apr 18, 2009 | 12:48 AM
Already checked the turn signals for blinking. But thank you. I never mean to be condescending to anyone, but I dont always know who I'm talking to, or their level of experience. I try to start with the basics and then help them from there.
Old Apr 18, 2009 | 08:25 AM
good work scott
Old Apr 18, 2009 | 10:45 AM
Polaradude's Avatar
We need more power Scotty.
Old Apr 18, 2009 | 03:49 PM
sgp7679's Avatar
i tried looking for the switch on the brake pedal arm but only found this thing that might be the switch. Are the switches in the front or back of the arm? the thing I found was on the front.
Old Apr 18, 2009 | 04:28 PM
That should be it. What you want is to find 12v at the switch. You Should find 12 v at one side of the switch and on both sides when the pedal is depressed. If you dont get a reading on both sides when depressed, make a jumper wire and then check the lights. On your car, do the brake and turn sigs use the same bulb or are they separate?
Old Apr 18, 2009 | 04:39 PM
I just googled "65 coronet wiring diagram". Theres tons of stuff. Print up the one that applies to your car and engine.
Old Apr 18, 2009 | 11:45 PM
sgp7679's Avatar
ok ill check that out.
AliceSML79
Aug 22, 2014 03:28 AM
1966charger
Apr 22, 2012 08:27 PM
Plyduster318
Sep 22, 2007 05:32 PM
buddahluvaz
Apr 20, 2007 07:37 PM
