FlowTech Purple Hornie Mufflers
Anyone running FlowTech's Purple Hornie Mufflers?
Looking at exhaust options, and was flirting with the idea of running these, got a feeling they would be loud as they would exit under the car below the seats!
yes they are loud but I would try to have them exit at least to the rear axle. or maybe out side the car in front of the rear tires. The fumes will get to you otherwise. Not much backpressure though . Might be alittle bit quieter if you install an H pipe.
not nessecarily. your stock system is about as restrictive as you want to go. sometimes adding in a little better flowing exhaust system will actually help to increase the gas mileage. it all depends on the vehicle and motor though.
