FlowTech Purple Hornie Mufflers
Old Jul 5, 2009 | 09:42 PM
64fury's Avatar
Anyone running FlowTech's Purple Hornie Mufflers?
Looking at exhaust options, and was flirting with the idea of running these, got a feeling they would be loud as they would exit under the car below the seats!
Old Jul 5, 2009 | 11:23 PM
theomahamoparguy's Avatar
yes they are loud but I would try to have them exit at least to the rear axle. or maybe out side the car in front of the rear tires. The fumes will get to you otherwise. Not much backpressure though . Might be alittle bit quieter if you install an H pipe.
Old Jul 6, 2009 | 03:27 AM
with less back pressure, you'll need some good low end power. Low back pressure is great for high rpm running motors, not so much for daily drivers.
Old Jul 6, 2009 | 05:54 PM
never have pipes end under the seats
the fumes get back in the car
Old Jul 6, 2009 | 07:04 PM
I had the exhaust dump down 3" behind the cab on my 2000 dakota. Man was that thing loud w/flowmaster 40! Very little to no backpressure so my milage sucked.
Old Jul 6, 2009 | 07:36 PM
Red Devil's Avatar
Little Demon
maybe this is a newb question, but does backpressure increase fuel mileage?
Old Jul 6, 2009 | 08:23 PM
backpressure increases torque
this is why flatheads have very good torque
decreasing backpressure is ok up to a point, ex. headers, but too much of it will decrease the efficieny of the motor
Old Jul 7, 2009 | 01:49 AM
not nessecarily. your stock system is about as restrictive as you want to go. sometimes adding in a little better flowing exhaust system will actually help to increase the gas mileage. it all depends on the vehicle and motor though.
Old Jul 7, 2009 | 09:35 PM
64fury's Avatar
Thanks guys!
Going to keep it simple, run straight pipes to the back with a pair of cherry bombs, and maybe some chrome tips! The purple hornies looked cool, maybe next time!
Old Jul 9, 2009 | 04:46 PM
how are you going to have the pipes done over the rear end?
try to keep it away from the brake line
1968newport
Dec 27, 2013 07:18 PM
inri
Aug 22, 2013 06:19 PM
rc-ltu
Mar 5, 2011 11:56 PM
Jan 13, 2009 10:25 AM
deadkelly
Jan 1, 2008 02:37 AM
