fuel pump
Old Jan 17, 2009 | 01:40 PM
sgp7679's Avatar
Question fuel pump
i pulled my dipstick and it smells like gas. Im thinking it my fuel pump leaking into my crankcase and it flooded it out and thats what caused my car to stall and not start again. Does this sound right?
Old Jan 17, 2009 | 04:44 PM
you can always pull the fuel pump or timing cover and investigate. Either way, it looks like you'll be tearing into the motor.
Old Jan 17, 2009 | 09:26 PM
sgp7679's Avatar
i was thinking this because someone told me that the pumps diagraphram could be bad and leak gas into the crankcase.
Old Jan 18, 2009 | 09:16 AM
i would think it is more likely that gas got past the rings
Old Jan 18, 2009 | 09:33 PM
sgp7679's Avatar
im gonna change out the pump tommorow because the carb i have on the car is new and i dont think its that because when i had it running it was running real good. The car was sitting for 4 years with gas in it before i got it so im pretty sure the pump needs replaced.
Old Jan 19, 2009 | 09:05 AM
is the 4 year old gas still in the car?
unless is was stored with a stabilizer, i'd get rid of the gas
Old Jan 19, 2009 | 09:08 AM
X2 on the old gas.
If there was any gas in the carb over those 4 years, it could have leaked down through the intake, heads and rings into the oil Very unlikely, I know). Have you had the car running before you smelled gas in the oil?
Old Jan 19, 2009 | 09:33 AM
sgp7679's Avatar
well when i got the car i removed all the old gas. after it would run for a bit it would have gas in the oil.
Old Jan 19, 2009 | 02:40 PM
Polaradude's Avatar
You may have pumped shellac or dried out gas from the pump itself or the lines into the new carb and stuck a float ?
Old Jan 20, 2009 | 03:29 PM
challenger's Avatar
where do you live at sgp7679 what state ???
Old Jan 24, 2009 | 10:43 AM
sgp7679's Avatar
texas
Old Jan 25, 2009 | 08:40 PM
challenger's Avatar
darn thats a little far for me thought if you were close i would come and get it running for you but i dont make it out that way sorry
Old Jan 28, 2009 | 10:56 AM
sgp7679's Avatar
well thnkx anyways
Old Jan 28, 2009 | 10:58 AM
Polaradude's Avatar
Any update on the problem, find anything new ?
Old Feb 9, 2009 | 03:47 PM
sgp7679's Avatar
well today my neighbor came over to help me out and when i went to turn the car over, the engine made a really loud pop. It sounded like a gunshot. Has anyone had this happen?
Old Feb 10, 2009 | 03:36 PM
sgp7679's Avatar
it not from the exhaust, it was up in the engine area, i didnt see exactly where it came from because i was in the car. I just hope nothing is messed up. Im thinking its the timing chain now, how it just died on me and i know for sure its getting gas and spark.
Old Feb 10, 2009 | 07:15 PM
sgp7679's Avatar
i think maybe the timing chain has jumped a few teeth. Has anyone ever had this happen or heard of this happening?
Old Feb 11, 2009 | 06:02 PM
  #24
did you replace the timing chain and gears?
if not, its probably old and sagging, which would cause it to slip
mopars&vampires
Jun 23, 2009 09:31 PM
nailbender
Dec 6, 2008 07:11 PM
nailbender
Nov 27, 2008 09:20 PM
skymynx
Oct 21, 2008 07:15 AM
rapidride2
Mar 20, 2007 05:58 PM
