Gas gauge issue
Old Feb 24, 2019 | 03:14 PM
My72D100's Avatar
Gas gauge issue
Afternoon class,
Got a 72 D100 with the tank in the cab. Gas gauge worked awhile back but now on start up it will move to the E and stop. Won't go pass E. I keep the truck topped off but would like to get the gauge working again. Any recommendations? Thanks guys.
Old Feb 24, 2019 | 03:22 PM
Unplug the wire at the sender.... Ground the wire and see if it goes to full? With the key on?
Old Feb 24, 2019 | 03:32 PM
My72D100's Avatar
It don't move at all
Old Feb 25, 2019 | 01:16 PM
Gauge is no good... Or the wire is no good.
Do the same thing at the back of the gauge. If it goes full. the gauge is good. If not the gauge is not good.
Old Feb 26, 2019 | 03:06 PM
wreklus's Avatar
If this is the only problem you're having with it right now, it might be worth the money to replace the gauge and wires anyway.
For one, your tank is in the cab. So, you won't have to crawl under the vehicle to replace the whole assembly.
And two, when wires or electronic parts start going bad it's usually a good idea to take the time to give the rest of the wires and contacts nearby a look to make sure you don't have more surprises coming up soon. Corrosion and damage often effect more than one wire at a time.
Old Feb 27, 2019 | 04:09 AM
My72D100's Avatar
Which side of the gauge do I ground? There is two threaded rods coming out the back? Thanks
Old Feb 27, 2019 | 04:29 AM
My72D100's Avatar
Which side of the gauge do I ground there is two threaded rods coming out the back that screw on the board.
Old Feb 28, 2019 | 05:33 AM
Should be the same color wire that was at the sending unit back at the tank......
Giantsbane
Jan 7, 2017 09:35 PM
moe7404
Mar 1, 2014 04:56 PM
04 Diesel
Jun 11, 2013 06:16 PM
bulldog
Sep 24, 2012 10:14 AM
sgp7679
Mar 18, 2009 11:05 PM
