Sponsored by:
Sponsored by:
Gas gauge issue
Old 02-24-2019, 03:14 PM
My72D100's Avatar
Gas gauge issue
Afternoon class,
Got a 72 D100 with the tank in the cab. Gas gauge worked awhile back but now on start up it will move to the E and stop. Won't go pass E. I keep the truck topped off but would like to get the gauge working again. Any recommendations? Thanks guys.
Old 02-24-2019, 03:22 PM
Unplug the wire at the sender.... Ground the wire and see if it goes to full? With the key on?
Old 02-24-2019, 03:32 PM
My72D100's Avatar
It don't move at all
Old 02-25-2019, 01:16 PM
Gauge is no good... Or the wire is no good.
Do the same thing at the back of the gauge. If it goes full. the gauge is good. If not the gauge is not good.
Old 02-26-2019, 03:06 PM
wreklus's Avatar
If this is the only problem you're having with it right now, it might be worth the money to replace the gauge and wires anyway.
For one, your tank is in the cab. So, you won't have to crawl under the vehicle to replace the whole assembly.
And two, when wires or electronic parts start going bad it's usually a good idea to take the time to give the rest of the wires and contacts nearby a look to make sure you don't have more surprises coming up soon. Corrosion and damage often effect more than one wire at a time.
Old 02-27-2019, 04:09 AM
My72D100's Avatar
Which side of the gauge do I ground? There is two threaded rods coming out the back? Thanks
Old 02-27-2019, 04:29 AM
My72D100's Avatar
Which side of the gauge do I ground there is two threaded rods coming out the back that screw on the board.
Old 02-28-2019, 05:33 AM
Should be the same color wire that was at the sending unit back at the tank......
Giantsbane
01-07-2017 09:35 PM
moe7404
03-01-2014 04:56 PM
04 Diesel
06-11-2013 06:16 PM
bulldog
09-24-2012 10:14 AM
sgp7679
03-18-2009 11:05 PM
Quick Reply: Gas gauge issue
