greenish exhaust fluid?
Old 06-23-2009 | 06:51 PM
No that is not normal. You could have a blown head gasket or a cracked head. I'd do a compression test on all of the cylinders.
Old 06-23-2009 | 07:38 PM
have you over-heated lately?
if you did, you might have warped the head
Old 06-24-2009 | 01:50 PM
carlosg7915's Avatar
Member
i had that happen to me on a moped when i was 16. i was told it was gunk and buildup on pistons and walls... since i kept pedaling to start it, the pistons pushed it out threw the exaust. anyways sounds like old oil and water mixed
Old 06-24-2009 | 06:27 PM
theomahamoparguy's Avatar
might have a loose exhaust stud. [really wild guess] Notice any leaking fron the engine?
Old 06-25-2009 | 01:22 PM
challenger's Avatar
have you checked to see what your plugs look like - look to see if they are wet with gas or antifreeze and what moparguy said isnt all that silly so i would also check that as it will blow into the exh-manifold and i would even look on top in the rad to see if you have any oil floters
frogjumper
03-20-2011 11:05 AM
elsmootho
08-17-2010 04:18 AM
skatefast91
05-28-2010 05:46 PM
gonn6d
11-09-2009 03:40 AM
jar84203
08-28-2009 04:49 AM
