greenish exhaust fluid?
Old Jun 23, 2009 | 05:51 PM
No that is not normal. You could have a blown head gasket or a cracked head. I'd do a compression test on all of the cylinders.
Old Jun 23, 2009 | 06:38 PM
have you over-heated lately?
if you did, you might have warped the head
Old Jun 24, 2009 | 12:50 PM
carlosg7915's Avatar
Member
i had that happen to me on a moped when i was 16. i was told it was gunk and buildup on pistons and walls... since i kept pedaling to start it, the pistons pushed it out threw the exaust. anyways sounds like old oil and water mixed
Old Jun 24, 2009 | 05:27 PM
theomahamoparguy's Avatar
might have a loose exhaust stud. [really wild guess] Notice any leaking fron the engine?
Old Jun 25, 2009 | 12:22 PM
challenger's Avatar
have you checked to see what your plugs look like - look to see if they are wet with gas or antifreeze and what moparguy said isnt all that silly so i would also check that as it will blow into the exh-manifold and i would even look on top in the rad to see if you have any oil floters
frogjumper
Mar 20, 2011 10:05 AM
elsmootho
Aug 17, 2010 03:18 AM
skatefast91
May 28, 2010 04:46 PM
gonn6d
Nov 9, 2009 02:40 AM
jar84203
Aug 28, 2009 03:49 AM
