Head gasket recommendations
Old May 15, 2016 | 07:05 AM
SPAMBURGER's Avatar
Just wondering what head gaskets people are using for their 440's. I think I blew mine out when breaking in the cam. it runs fine but I'm getting a lot of water in the oil and out of the pipe.
Old May 15, 2016 | 07:14 AM
A little lite on info..... But Fel-Pro's work ok in my book....
Old May 15, 2016 | 10:50 AM
Fel Pro with a fire ring for iron heads, I use Cometics for aluminum heads, no fire ring which will "dent" the aluminum.
Old May 15, 2016 | 11:36 AM
SPAMBURGER's Avatar
The heads are 915's, the block is stock bore as far as I know. The head gaskets I was using are the fel-pro 1009. Should I stick with that or is there something that might seal a little better? I think part of the reason it blew was that a couple of the spark plug wires got a little too close to the headder and were melted while I was braking in the cam.
Old May 15, 2016 | 11:44 AM
I'm still using up my supply of nos mopar steel gaskets.
Old May 15, 2016 | 12:04 PM
As long as the compression is not crazy.. Fel-Pros are fine. When you pull the heads your going to have to make sure the block deck and the head surface are flat all over again... Also.. Make sure all the head bolt yeided the torqe to spec.
Old May 15, 2016 | 03:18 PM
Great advance!....... It doesn't matter what gasket your using if surface isn't flat and true!!!!
Old May 15, 2016 | 05:53 PM
I'll store that in the "Need to know" file.....lol
Old May 16, 2016 | 04:54 AM
In all the big blocks I've put together, I have never had a problem with head gaskets.
Not once....
Old May 16, 2016 | 08:28 AM
Rooty's Avatar
Who evers head gaskets you use make sure you know the final compression thickness before installing. Fel-pro has the specs on their site.
Old May 16, 2016 | 06:39 PM
Not once....
I have also had nothing but good luck with steel shim... Mine worked great till about 11.5.1CR. Just saying....
You are soo old school....lol... Shhhhhh me too...Hahahahahaha
Old May 17, 2016 | 11:12 AM
I use them in my 12.5 motor, but block and heads have been cut so they are true.
Bob my signature says it all!
Old Aug 19, 2016 | 08:41 AM
How is that truck running SPAM ? Or is it not fixed yet??????
Old Aug 20, 2016 | 01:09 PM
SPAMBURGER's Avatar
I'm still having problems. I removed the head again last week and am now looking for cracks. I'm about to throw in the towel and buy a set of heads from Hughes engines. It's frustrating to have this thing so close to being finished and have a problem like this.
Old Aug 20, 2016 | 02:52 PM
Hummmm. So are the surfaces not flat on the head and block?
Has it blown out the head gaskets again?
Did you check to see if (When you had the heads off) all the cylinders were free of any cracks?
Hope you find it here soon..
Old Aug 21, 2016 | 05:33 AM
Check the block, very good chance block is not square, look at heads again and make sure they are flat and true.
This is all basic rebuild stuff that gets overlooked because of cost, but on a performance build should be standard.
Old Aug 29, 2016 | 07:34 PM
SPAMBURGER's Avatar
Well, I double checked the block and heads and they are as good as the mechinest said they were. I pulled the valves from the leaking cylinder and didn't see any crackes or imperfections. I reassembled everything with a new head gasket and now it is running fine with no smoke at all. On the old head gasket I did notice a little indent into the cylinder that was getting wet almost like a flat spot in the ring. I hope this fixes the problem but I will continue to watch it. Thanks for the helps guys.
Old Aug 29, 2016 | 09:04 PM
Might re torque the head after about a week...
Old Aug 30, 2016 | 03:34 PM
Glad to see things are going your way. sometimes it's a little thing that gets ya.
Old Jul 25, 2017 | 10:22 AM
SPAMBURGER's Avatar
Well after almost 2 years and 6 times pulling the heads the shop I took them too found 3 places that the first guy cut into the water jacket while porting them. So now I'm on the hunt for new closed chamber heads to go with everything I have done. If anyone knows of any for sale for a good price let me know.
Old Jul 25, 2017 | 06:21 PM
Not weldable?
Old Jul 25, 2017 | 08:05 PM
SPAMBURGER's Avatar
Not weldable?
I don't think it would be worth it. They are 915's that I had 2.14/1.81 valves put it and opened up but I guess the guy went too far. They already had some port work done so it is kind of my word against his so he isn't even going to pay for it. The shop that finally found the problem had to pressure test them. I'm just thinking of going with some CNC ported RPM heads from Hughesengines.com but I guess I will need rockers and push rods if I go aluminum.
Old Jul 26, 2017 | 02:22 PM
Check with Andy F. over at Gray's Automotive over in Oregon... He might have something that might fit your need... Or you can find him over on "For A Body Only"...
tagster
Sep 9, 2010 01:04 PM
jascharger
Jul 14, 2010 07:04 PM
sgp7679
Jan 7, 2010 12:58 AM
DUST360
Jun 22, 2009 09:32 PM
MarkyMark12345
Apr 16, 2009 06:46 PM
