hi everybody =] i miss the forum. you guys helped me a lot
Old 09-03-2009 | 09:10 PM
carlosg7915's Avatar
Member
i guess its about time for my 440 to get rebuilt. Wondering if i should let my neighboor rebuilt the engine in his own house ir should i bring it to a professional insted? what do u guys think?
Old 09-04-2009 | 03:40 AM
How good is your neighbor? What kind of background does he have and how well do you trust him?
Old 09-04-2009 | 08:40 AM
crmzendrgone's Avatar
Yes TRUST is a very good thing, is he clean will he do a clean job I was always told cleanliness is close to Godliness when it comes to building engines.
Old 09-04-2009 | 09:37 AM
well first off, what needs to be done to the motor?
Old 09-05-2009 | 07:53 AM
Member
hes really good and knows his stuff. but hes messy as hell. gtx i really dont know whats wrong wit it. i've been so madd i havnt let anyone look at it. thing makes all kind of noises in the engine. it over heated on me and started smokin.
Old 09-05-2009 | 06:40 PM
scotts74birds's Avatar
Howdy Carlos. Overheated can make bad things happen, usually cracked head or blown head gasket. Hope its not serious. depends on the neighbor for the rebuild. If you use a pro, make sure they run a neat shop, organized and clean. That reflects their work habits and attention to detail.
Old 09-05-2009 | 07:41 PM
67gtxclone's Avatar
I agree with the rest about the cleanliness thing. I would really think twice about having someone rebuild my engine who does not keep a clean shop. He may be good, and it is ultimately your call....just something to think about.
Also, it would be a good idea to do some investigation on what the actual issue is, you may not need a complete rebuild.
Old 09-06-2009 | 02:47 PM
Member
we'l i let my mechanic look at it. the reason why the heads are making noise is because the oil pump went. =] im so freakinnn exited, car should be running again in no time. he told me to get a hi-capacity oil pump since its a 440. should i get a hi-capacity one or not?
Old 09-06-2009 | 02:53 PM
Member
scotty wats goin on mann!? =] I think we got the problem downpack. doesnt need a rebuild. needs a oil pump. hopefully everything goes smoothh
Old 09-06-2009 | 06:04 PM
why would the heads make noise if the oil pump is going?
if the oil pump is going, your oil pressure will start to flucuate
Old 09-06-2009 | 06:06 PM
here is what i would do
pull the pump off, its easy to do on a 440
buy a new gasket when you put it back
never reuse the old one
look at the gears inside
if they are chipped, you need a new oil pump
if they are not chipped, you need to use a feeler gauge and measure the distance between the gears (i dont know the gap, sorry)
Old 09-06-2009 | 07:00 PM
Member
i'l make sure i mention all this to my mechanic. the car turns on perfect and idled fine. does not smoke. he mentioned sumthing about since the pump isnt pumping all the oil is at the bottom. does this sound right?
Old 09-07-2009 | 04:31 AM
Could be a clogged pick-up tube or screen.
Old 09-07-2009 | 09:43 AM
Member
i'l make sure to mention this to him also.
Old 09-07-2009 | 12:10 PM
what kind of noises are coming from the heads?
Old 09-07-2009 | 01:39 PM
Member
sounds like the pistons are running dry
Old 09-07-2009 | 03:11 PM
do you have an oil pressure gauge in your car?
Old 09-07-2009 | 04:31 PM
Member
nope.
Old 09-07-2009 | 05:20 PM
i would definetly install one man
it will give you protection, and it will tell you if your pump is going bad if you don't want to pull it
Old 09-08-2009 | 07:55 AM
Second that all both of those. I was told once while talking about a rebuild that I need to decide if i want a high capacity or a high velocity. But I never got a good answer on which one. Maybe someone here could explain which is better?
Old 09-08-2009 | 08:12 AM
Member
i was meaning to ask that.
Old 09-08-2009 | 08:37 AM
my 440 was a high pressure pump
when I get on it, the gauge pins at 100
but, you should be fine with a 60-80 pound pump
the general rule is 10 pounds for every 1000 rpm
Old 09-08-2009 | 06:48 PM
deadkelly's Avatar
remember to prime the pump , just put the priming shaft in a drill turn it on till you feel it load up & all good very easy . good to back from ya carlos .
12-22-2012 02:23 PM
oldiebutgoodie
10-04-2012 07:27 PM
scott2683
05-15-2011 11:42 AM
Crazy4Carz.Com
09-28-2009 11:57 AM
06-13-2009 08:43 AM
Quick Reply: hi everybody =] i miss the forum. you guys helped me a lot
