High Speed shakes!!! (but no rattles or rolls)
Old Jul 13, 2009 | 08:41 PM
64fury's Avatar
Hi Guys!
Last week I noticed a shake in the steering of my Fury while at highway speeds, felt like the front passenger wheel was out of balance so I took both fronts off and had them balanced. Put them back on tonight and went for a drive!
The shake is still there, it's coming from the right side or the centre of the car. The car had an alignment last summer with only a few dozen miles clocked up since, and the wheels have been balanced.
The shake only happens above 100 kph and gets worse as you go faster, you feel the shake first thru the floor boards then thru the steering wheel! And a change in RPM does not effect the shake.
Any suggestions where to start looking? Transmission mounts, engine mounts, prop shaft, u-joints, front drums out of balance? I can think of a half dozen possible causes!
On a bright side the Fury seams to be shifting better now, played with the kick-down linkage a bit, not perfect but there was a noticable improvement!
Slowly this car is getting road worthy!
Old Jul 13, 2009 | 09:25 PM
scotts74birds's Avatar
Wheel bearings? Ive seen them installed wrong, not fully seated before tightening. A broken belt in a tire wont show up on a balancer if you arent looking at it. They just shut the lid and put the weight where it says. Any uneven wear on only one section of a tire? Just suggestions from things that have happened to me.
Old Jul 13, 2009 | 09:32 PM
theomahamoparguy's Avatar
agree with 74birds on the tire deal. Check it for bumps in the sidewall.
Old Jul 14, 2009 | 03:32 AM
Polaradude's Avatar
x3 on the above mentioned.
Old Jul 14, 2009 | 06:10 AM
64fury's Avatar
Check the tires, no visible bumps, humps, bulges etc! Switch tires, passenger to drivers side and the shake is still there on the passenger side/center!
Well off to work, will look again when I get home!
Old Jul 14, 2009 | 09:02 AM
Polaradude's Avatar
Originally Posted by richinny
jack the rear and chock the front wheels and GENTLY run the can and see if anything falls out ;-)
You thinking U-joint ?
Old Jul 14, 2009 | 10:14 AM
johnthegoalie's Avatar
thinkin with me dipstick
correctumundo - go under the car and see if there is sideways play around the u-joints.
Old Jul 14, 2009 | 12:35 PM
You can do that without putting the car into drive. All it takes is just one cap that is not greased for a vibration. If that is not the case, then i would start to look for flatspots on the tires. If you just did a brake job or have drums all the way around, make sure that you did not lose any of the weights that are used to balance them.
Old Jul 14, 2009 | 06:01 PM
64fury's Avatar
Only have one u-joint at the rear, it seams tight and well greased, the front dosn't look like a typical u-joint, more like a slip yoke or cv-style joint!
Old Jul 14, 2009 | 08:17 PM
mahd's Avatar
i think that it might be the wheel bearings. try replacing them it should fix it.
Old Jul 14, 2009 | 09:48 PM
dingo's Avatar
Junior Member
Back off the front wheel bearings and them retork them instead of spending money thats not needed. Also check ball joints. Jack up the car and try to wiggle the tire side to side and top and bottom. Hope this helps. I would hate to see you spend money not needed.
Old Jul 15, 2009 | 10:31 AM
Mopar_71's Avatar
If you suspect it to be tire or wheel related, I just went through this..
Put the wheel you suspect on the rear end. Jack up the rear and support it.
Point the car away from anything if it were to fall, but it wont.
Start the car and put it in drive. Watch the wheel rotate. If it's a bent rim, you will see it right away. Most tire shops don't look for bent rims. they just balance the the tire...
Good luck
Old Jul 15, 2009 | 10:16 PM
64fury's Avatar
Wasn't going to go buy new bearings, until I tried re-packing the old ones!
Pretty sure it's not the wheels or tires at this point!
Was playing with the car tonight, found quite some play (1/4 turn) in the steering box, could this be a possible cause?
On a unrelated note, I received my Mopar electronic ignition kit today! Thinking about taking friday off work to put it in! But don't tell the boss!
Old Jul 15, 2009 | 10:44 PM
dingo's Avatar
Junior Member
how bad is the shake in the steering wheel?
Old Jul 16, 2009 | 05:34 AM
64fury's Avatar
does it shake more after hitting some bumps?
does it shake the same on turns?
Nope only shakes at high speed on flat smooth road, haven not had it at high speed on a non flat bumpy road!
Old Jul 17, 2009 | 06:20 PM
elsewhere's Avatar
Junior Member
You have a Ball and Trunnion u-joint on the front. If the boot is in good shape and it is full of greese, they last forever. I had a car that developed a bad shake around 40mph. It was the tie rod ends. they have really tight since it is a tapered fit. Jack the car up and grab each wheel on the side to turn the tire. look at the tie rods, idler arm and pitmin arm to see if there is any play.
JS23
Dec 18, 2014 07:12 AM
moe7404
Mar 15, 2014 01:37 PM
chuck1934
Sep 29, 2012 10:21 AM
ShowYourAuto.com
Mar 18, 2011 11:24 AM
jrdan98
May 25, 2010 12:46 PM
