How to tell what engine a Valiant had from vin?
Old Jul 1, 2013 | 09:29 PM
Valiant EVfort's Avatar
Hi does anyone know where I would look up the engine code for my `63 valiant to find out what it originally had? Also is there a good rear end identifier recommendation? I have a 10 bolt cover posi rear that IIRC came out of a `70 Mopar with a 440 and while it resembles a Dana 60 I am not sure if that is what it is.
Old Jul 1, 2013 | 10:41 PM
Post the VIN and someone will run it for you (senior member or mod/admin). As far as your rear axle goes, here is a good thread to follow with pics. If you are still unsure, post up a pic of it.
https://moparforums.com/forums/f76/a...hematics-7801/
Old Jul 1, 2013 | 10:51 PM
Thanks Tim,
The casting # on it is 2852905 so axle is an 8 1/4" and from what I gather the posi is the Sure-Grip unit. The axle is approx 64" from flange to flange (wheel mounting surface) outside to outside of drum face so I am still trying to figure out what car it came from but I am a lot closer than I was before. Thanks again. Dach.
Old Jul 1, 2013 | 10:54 PM
Valiant Vin#
>Post the VIN and someone will run it for you (senior member or mod/admin).<
Cool, here is the vin# 1135165363. Thanks Dach.
Old Jul 1, 2013 | 11:16 PM
63 90% chance you had a 170ci 6cyl motor
Old Jul 1, 2013 | 11:29 PM
moe7404's Avatar
the easy way to tell the difference from a 170 or a 225. with the head and ext manifold on. if you can pass your thumb between the ext manifold and the back side of the water pump casting you have a 225. if it is all most touching it is a 170.
Crazy4Carz.Com
Nov 21, 2009 09:07 AM
plymouth
Aug 5, 2009 01:49 PM
craveman
Apr 17, 2009 04:13 PM
Crazy4Carz.Com
Nov 6, 2008 05:31 AM
