lifter
Old Mar 1, 2010 | 03:07 PM
juven's Avatar
lifter
i have a 74 duster with the 318. i took the engine out when i first started restoring it so it could be gone throght and refresed. i put it all back in but now when it runs it has a clicking noise. i found out that it was one of the lifters not priming up all the way. its a brand new lifter and i have no diea why its doing that. any suggestions on how to fix it?
Old Mar 1, 2010 | 09:57 PM
theomahamoparguy's Avatar
will have to replace it I think. one lifter should not cost too much. (though the replacing it is a pain in the a$$) [need to check preload and cam wear on that lobe]
Old Mar 2, 2010 | 03:52 PM
scotts74birds's Avatar
Just a thought.....There was a recent post about a 318 with an oversized lifter bore. See this link https://moparforums.com/forums/f62/o...d-lifter-5504/ That might cause a lifter to fail to pump-up. I'm not saying this is the case, but it wouldnt hurt to check!
Old Mar 3, 2010 | 02:05 PM
did you replace all the lifters when you put the engine back in?
this might help: https://moparforums.com/forums/f62/o...-engines-2333/
Old Mar 7, 2010 | 07:01 PM
juven's Avatar
yes i replaced all the lifters. they are all brand new.
Old Mar 8, 2010 | 03:30 PM
did you break them in correctly?
Old Mar 12, 2010 | 08:31 AM
juven's Avatar
i think so. i had help with that.
Old Mar 12, 2010 | 01:35 PM
did you read the link i posted?
it could be your problem
Old Mar 13, 2010 | 12:21 AM
1966sportfury's Avatar
A.K.A Bob Dodge
incorrect break-in wouldnt cause a lifter not to pump up. (lobe wear yes) maybe it has blockage? hyd, liflters are easy to dis-assemble and re-assemble. theres 3 types of locks on a lifter. open it up check for blockage and re-assemble.. its that easy
RustyBucket
Feb 24, 2014 08:05 PM
lifted150
Dec 26, 2011 06:23 PM
will d
Feb 27, 2010 06:29 PM
Erikthegoalie
Feb 9, 2009 03:34 PM
62sportsweep
Apr 7, 2008 03:38 PM
