motor help !!!!
motor help !!!!
i have a 440 .60 over with a mild cam holley 780 vac ..........it seems like it is doggin on power i have new plugs wires and everything but i cant get it to stop running rich i have try screwin with the carb but i just dont know, so i have come to you guys to help me ........should i cant my timing and if so what should my timing be set at plz help thanks nate
Try to limit the total mechanical {no vacuum advance} to 34-36.
Guest
Posts: n/a
Could have the incorrect power valve, or it could be ruptured. floats could be set wrong, when a Holley isn't working right they can be a real pain, that's why I use Edelbrock/Carter carbs on my daily drivers. Holleys will usually make a couple more HP. but it seems like people are always having to wrench on them to get 'em right.
