motor help !!!!
Old Apr 13, 2009 | 12:22 PM
mopar nate's Avatar
motor help !!!!
i have a 440 .60 over with a mild cam holley 780 vac ..........it seems like it is doggin on power i have new plugs wires and everything but i cant get it to stop running rich i have try screwin with the carb but i just dont know, so i have come to you guys to help me ........should i cant my timing and if so what should my timing be set at plz help thanks nate
Old Apr 13, 2009 | 04:01 PM
theomahamoparguy's Avatar
If you have a cam in it I would try about 10-12 degrees of initial advance.
Try to limit the total mechanical {no vacuum advance} to 34-36.
Old Apr 13, 2009 | 07:39 PM
did you ever mess with the jets in the carb.?
Old Apr 13, 2009 | 11:35 PM
mopar nate's Avatar
no i never played with the jets
Old Apr 14, 2009 | 02:13 AM
Play with the timing some as the smoother the motor runs, the more power she will make faster.
What octane gas are you running?
Old Apr 14, 2009 | 11:17 AM
mopar nate's Avatar
i been running 89 because 93 lil expensive and i have no job i was laid off so i still try to run a high octane...
Old Apr 15, 2009 | 06:45 AM
rr69half6bbl's Avatar
I agree w/ hyper, if you arent familiar w/ a holley maybe have a wrenchin buddy dial it in for you, theyre nto that hard to figure out ounce someone shows you how.
Wingnut009
Sep 21, 2011 11:03 AM
mopar nate
Apr 29, 2009 06:54 PM
frankie
Nov 25, 2008 11:53 PM
70chargerrt
Jun 20, 2008 12:48 AM
strean
Feb 20, 2008 02:45 PM
