NEED HELP!!
Old Jan 9, 2009 | 02:20 PM
sgp7679's Avatar
Question NEED HELP!!
I got a problem. The other day I was pulling my car out of the driveway when it died on me. I Tried to restart it and nothing. I checked for spark and it looked kinda weak and i saw that the points were bad. I replaced the points with electronic ignition and now it gets good spark. I go to start the car and it still dosent start. I thought maybe carb was dirty so i cleaned the carb out and tried to restart and still no luck. I put some gas down the top of the carb to see if it would start and it wouldnt. Any ideas what could be wrong? The car is a 65' coronet. What can i check or do? please help
Old Jan 9, 2009 | 02:44 PM
Polaradude's Avatar
Is the electronic ign. grounded properly ?
Old Jan 9, 2009 | 02:48 PM
sgp7679's Avatar
yes im pretty sure, its getting a good sized blue spark.
Old Jan 9, 2009 | 02:52 PM
Polaradude's Avatar
There were no ugly noises before it died ? If it just died like it was shot, I'd say your problem is electrical, I'd check the usual suspects like grounds etc.
Old Jan 9, 2009 | 03:03 PM
sgp7679's Avatar
yeah it just died, no weird sound or anything. If its getting spark, what should i check?
Old Jan 9, 2009 | 03:14 PM
Polaradude's Avatar
The starter will crank ?
Old Jan 9, 2009 | 03:16 PM
did the car sputter?
Old Jan 9, 2009 | 03:17 PM
Polaradude's Avatar
Maybe there's Chev parts in it...
Old Jan 9, 2009 | 03:20 PM
sgp7679's Avatar
Yeah the starter cranks but it just keeps crankin and the engine wont fire. When the car died it kinda sputtered to a stop. What could it be???
Old Jan 9, 2009 | 03:26 PM
Polaradude's Avatar
Plugged fuel filter ?
Old Jan 9, 2009 | 03:28 PM
Polaradude's Avatar
Sorry bro, had to go back and re read the 1st post. Your timing ok ?
Old Jan 9, 2009 | 03:33 PM
sgp7679's Avatar
My fuel filters not plugged. gas goes freely through it. I dont know about the timing. How do i check this? Can it just get untimed like that? It was running real good before it just died.
Old Jan 9, 2009 | 06:20 PM
make sure your distributor is tightened
check your timing using a timing light and shign it to the crank balancer
it'll have marking on it
are you running mopar orange box electronic ignition?
make sure all wires are tightly in place
Old Jan 10, 2009 | 10:15 AM
sgp7679's Avatar
no im running pertronix ignition. If the timing messed up would it just do it when the cars going all of the sudden?
Old Jan 10, 2009 | 11:23 AM
crank the engine by hand to top dead center, and make sure the distibutor is pointing to the number one cylinder
Old Jan 11, 2009 | 11:18 AM
challenger's Avatar
sounds like when you switched distributors (im assuming you did) i would make sure you put it back in the right place and after you check that i would try starting fluid and maybe you saturated the plugs so you might want to change them out
Old Jan 11, 2009 | 07:38 PM
sgp7679's Avatar
i didnt change out the whole distributor, just the points in it. Could my timing get messed up while im driving the car?
Old Jan 12, 2009 | 01:05 PM
probably not, unless your distributor is loose
Old Jan 12, 2009 | 03:45 PM
challenger's Avatar
what 67 says but did you get the carb back together ?? and is that the problem
Old Jan 12, 2009 | 04:23 PM
did you try this?
Old Jan 12, 2009 | 05:30 PM
sgp7679's Avatar
the carb is togther and working and i havent tried the tdc timing yet.
Old Jan 12, 2009 | 05:40 PM
any improvement with the carb working now?
Old Jan 12, 2009 | 05:53 PM
challenger's Avatar
so how did you get the plunger in ? just woundering if it went back together ok for you, and try and get the timing on and see if it runs any better for you
Old Jan 12, 2009 | 06:15 PM
  #24
sgp7679's Avatar
yeah luckily i had another plunger laying around. The timing is good so now i think its the plugs. I had these plugs with my old carb that ran really rich and i looked at them and their black so i think their fouled out. Ill replace them and see what happens. Can plugs foul out while driving?
Old Jan 12, 2009 | 07:21 PM
  #25
if the car is off, it is impossible to foul plugs
but, if at idle, and the carb was running extremely rich, then it is possible
Old Jan 12, 2009 | 07:52 PM
  #26
sgp7679's Avatar
well i cleaned up some old plugs and put them in and now it atleast tries to fire up but wont stay started. Ill try all new plugs tommorow.
Old Jan 13, 2009 | 02:33 PM
  #28
sgp7679's Avatar
i put in new plugs today and new coil and still nothing.
Old Jan 13, 2009 | 02:46 PM
  #29
Polaradude's Avatar
Sorry to keep buggin ya bro, but hows the timing ?
Old Jan 13, 2009 | 02:54 PM
  #30
sgp7679's Avatar
ill check the timing now but how do i know which cylinder is #1?
