NEED HELP!!
Old Jan 13, 2009 | 03:00 PM
  #31
any pistin can be your # 1, just make sure that it is at TDC
Old Jan 13, 2009 | 03:02 PM
  #32
Polaradude's Avatar
Here ya go buddy.
Old Jan 13, 2009 | 03:16 PM
  #33
sgp7679's Avatar
does anyone know how many turns the screws on the carb should be turned out? Timing is good. maybe its getting too much gas because it tries to fire but wont stay running
Old Jan 13, 2009 | 03:26 PM
  #34
Polaradude's Avatar
In all the way and then back 1.5 turns, good ball park to start from.
Old Jan 13, 2009 | 03:58 PM
  #35
sgp7679's Avatar
i adjusted carb and still no luck,this is really making me mad!! It has spark,and fuel and its timed right so it should be firing up. What could mess up while i am slowly moving in the car and just cause it to die??? Where are some common places that wires come loose or a ground goes bad because im thinking how it just died with no weird sounds, it just felt like you turned the ignition off, a wire somewhere is messed up.
Old Jan 13, 2009 | 04:10 PM
  #36
Polaradude's Avatar
Man I gotta tell ya I am lost, wish I was there to see whats up, but Barret Jackson just started so I gotta fly, the big screen's calling my name.
I can't think of what it would be if you have spark,gas and it's timing is on.
Old Jan 13, 2009 | 04:13 PM
  #37
sgp7679's Avatar
would the size of the carb gasket make it die? idk im just thinking of everything, When i installed the new carb it came with a new gasket and it was thin and the old gasket was really thick and made the carb sit higher up.
Old Jan 13, 2009 | 04:28 PM
  #38
challenger's Avatar
sgp check to make sure your wires are in the right spot as this can only be the only thing else wrong and are you sure you have the right plug and gaps on them and did you try starting fluid yet but sounds like the wires and maybe a vacuum leak that is to strong to let it start
1.check wires
2.check #1 plug wire
3.check for vacuum leak
4.check plugs
those are the only things i can see being wrong if you are getting fuel to the plugs......when # 1 cylinder is up make sure the rotor is pointing to the # 1 on the cap
Old Jan 13, 2009 | 04:59 PM
  #39
the gasket wouldnt affect it
to bring it to tdc, crank the engine until the timing mark is at 0
Old Jan 17, 2009 | 08:25 AM
  #40
sgp7679's Avatar
How does gas get in the oil? i pulled my dipstick and it smells like gas. Did i flood the car out?
Old Jan 17, 2009 | 10:08 AM
  #41
Polaradude's Avatar
It's when you have what some people call a wash out, un-burnt gas is left in the cylinder and it runs down the walls and into your oil pan removing oil from your cylinder wall...not good. It also thins out the oil in your pan...not good, this condition can toast your motor.
Old Jan 17, 2009 | 12:49 PM
  #42
sgp7679's Avatar
so should i just replace the oil and put some oil in the cylinders to relube them?
Old Jan 17, 2009 | 01:01 PM
  #43
sgp7679's Avatar
could it be that my fuel pump is messed up and flooding out the engine thats why it died and wont start?
Old Jan 17, 2009 | 06:43 PM
  #44
Polaradude's Avatar
You might have a float stuck on your carb letting too much gas into your engine causing the flooding condition. My suggestion is fix the fuel situation and then change your oil.
Old Jan 18, 2009 | 02:03 AM
  #45
BuckNeccid's Avatar
<~~ Was just thinking the same thing as Polardude. Float sticking, allowing it to flood out and die, extra fuel going into the oil. That'll wet your plugs and make it hard to start, and could also let it start and then die out.
When you're trying to find out which cylinder is number one to set your timing and firing order, a good rule of thumb is that which ever bank has the farthest forward cylinder also has number one as the front most cylinder.
Old Jan 18, 2009 | 04:20 AM
  #46
Polaradude's Avatar
If you still need the chart, check it out bro.
Rumblefish318
Jun 30, 2013 12:56 PM
73plymduster
Aug 15, 2010 10:21 AM
