Nice car but "manual automatic" pushbutton...??
Old Jun 1, 2012 | 06:46 AM
polyspherical's Avatar
So, I'm looking at this car on ebay, a really nice looking 63 Sport Fury, and listening the video walkaround where the guy says it has a manual-automatic, pushbutton transmission. He says you push the buttons to shift, but without a clutch. Huh?
I message the guy to explain to him that it's a normal torqueflite automatic transmission and the only difference is the linkage; buttons vs. shift lever.
He responds back with "Actually you do have to shift it manually. You start in drive then push for second then first. It's a blast to drive!! It is a automatic but you still have to go through the gears just no clutch. http://en.wikipedia.org/wiki/TorqueFlite"
How can someone who sells cars for a living be so clueless on something so basic??
http://www.ebay.com.au/itm/270988040...t_34029wt_1140
Old Jun 1, 2012 | 07:11 AM
MrOldart2U's Avatar
Well he IS a salesman... I did notice the car has sub-frame connectors of sorts on it, but didnt watch the vid. But maybe a manual valve body? But if so he's always down shifting!! Wonder if he has just pushed the D button and tried to just drive the car?
Old Jun 1, 2012 | 08:00 AM
It just might be that he is "somewhat" correct
MAYBE he's one of these guys who "doesn't understand"
IF the car has a reverse pattern manual valve body, THAT IS EXACTLY how the car will shift, IE
Drive will be first gear, the 2 button will be 2nd gear, and the 1 button will be 3rd gear
This was popular with "push button" drag racers to prevent hitting neutral or reverse during a race, as you were moving away from N/R as you progress
I myself run a reverse pattern manual body in my Dart, and I just love it. I wish I'd had one back in my "daily driver" days in the winter. Ford autos (once had a 78 Ferd LTD II, known as the "SKUD missile")
On the Ferd autos, when you put the shifter in "2" it is LOCKED in "2" unlike the Mopars/ GMs of the time, which shifted from 1 to 2 when placed in "2" Up here in the winter, I used that "2" position in that Ford to great advantage.
The manual valve bodies are same, IE "locked" in whatever single gear you place the shifter.
Old Jun 1, 2012 | 08:36 AM
Ah, reverse pattern manual valve body. That would make sense. Great for racing, but personally, I'd have it put back to original.
Thanks for that. I feel better now.
twood21
Mar 13, 2014 06:44 PM
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
1962dodge440
Sep 8, 2009 03:17 PM
EASTBAYJAY
Aug 3, 2009 12:49 AM
