Oil gauge still not working
Old Jun 4, 2016 | 02:50 PM
74Runneer's Avatar
It's been a while but I'm working on my 74 road runner again. It's a 318 auto. I can't get my oil sending unit to read a resistance. I took off the wire going to the bulk head and measured the resistance from the oil sending unit to the ground and my DMM reads infinity when set in the ohms setting, and this happens both with the engine on and off. I tested with another DMM and got the same results. I'm about at the point where I'm going to take it in for someone to fix because I can't figure this out, but I'm giving it one last try. Does anyone else know how to test a 74 oil sending unit? I bought it new a year or so ago but can't get it to work. Or maybe I don't know how it works. I'll post a picture of my sending unit but I'm fairly certain it's the gauge not the switch unit.
Thanks
Old Jun 4, 2016 | 04:13 PM
https://moparforums.com/forums/f62/i...-gauges-17717/
Old Jun 4, 2016 | 04:18 PM
74Runneer's Avatar
This was me struggling with it last year. Still haven't figured it out.
Old Jun 4, 2016 | 06:44 PM
Is the wire good from the sending unit to the cluster?
Check the wire for Continuity first..... Just my 2 cents..
http://en-us.fluke.com/training/trai...ultimeter.html
Old Jun 11, 2016 | 08:49 PM
Did you try a new sender ?
Old Jun 15, 2016 | 09:51 AM
peter123wallace's Avatar
Yap, this can help.
Old Jun 20, 2016 | 09:23 AM
Rooty's Avatar
I trust your using the right sending sensor. Some are straight "made/not made" for idiot lights on the dash and some are resistance style for graduated pressure gauges. Using a VOM meter in series set to 3000K will tell you what type you have when the engine is running and revved slightly.
belvedere383
Oct 9, 2014 06:46 AM
bulldog
Sep 24, 2012 10:14 AM
BruceJ
Oct 15, 2011 10:44 AM
dzltd02
Oct 28, 2008 08:25 AM
Plyduster318
Sep 22, 2007 05:32 PM
