plymouth 1937 engine swap
Old Sep 23, 2017 | 05:30 AM
peder's Avatar
hello,sweden calling,can you help me find a wiring diagram for a dodge van b250 1989,i have search the interweb but not found it,im putting a 318 tbi engine in a plymouth 1937 and want to use the original fuel injektion from the van but i need the wiring diagram for the computer,i knowe that its easier to put a carb and change the distributor but im a hard headed viking that never gives up on a prodjekt,so please help me
Old Nov 23, 2017 | 07:12 PM
dodgem880's Avatar
Hello
This is all I could find. I'm not sure if it will help or not.
http://www.increa.com/reverse/dodge-van-repair/
You will probably have to make detailed notes of the vans wiring harness and shorten or lengthen it as needed for fitment in the Plymouth. It probably would be best to buy a factory/dealer (not a Chilton or Haynes) service manual off online. (found one here on ebay)
I think I would address any of the vans running problems and trouble codes before pulling the van a part, that way you know any initial problems you have after the swap are new and not a per-existing problem.
Then, there is the question of the transmission. Are you using the one in the van? Is it manual? If no, you may need to switch to a ECU for a manual transmission application or the computer will throw a trouble code.
Instrument cluster, exhaust sensors, fuel tank, the list goes on.
Just some stuff I would think about.
Good Luck on your project.
From eBay
Old Nov 23, 2017 | 08:16 PM
Thumbs up
That should help him out, good find!
superk
Sep 8, 2017 04:51 PM
Oscbul
Jul 7, 2016 05:34 PM
mrwillys
Jan 9, 2014 04:19 PM
67hemidart
Feb 14, 2013 10:50 AM
brewster
May 10, 2007 03:58 PM
