por-15 paint
going to do my floors with por-15 paint ,,its very costly,but heard its the best and will last forever,,has anyone here used it,and what did ya think of the product?and second any links to a good insulator to put down befor i carpet her.....thanks
Scott, I used POR-15 a lot on my camaro, I painted the engine, subframe, and the trunk pan, it works great- expensive and there is another item out that call RPM - http://ecsautomotive.com/rpm.php and here is a MOPAR thread about it- http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1 I would look at this IMO. Hope it helps? As for sounderner I used HUSH MAT which was nice.
Joe
Joe
POR-15 works well, but if you get it onto any threaded holes you will need to chase them prior to installing a fastener. Failure to do so will result in broken bolts.
cool,,so no bad news on the stuff ,other than dont get it on ya ,,they dont make a solvent that can remove it it says on the can,,lol,,was over 50$ for a quart but its worth it i think
POR 15
After reading the attached post, I went to Ace hardware and got some of the Rust Stop paint. I used it and it is just like POR 15. Available in many colors in pints, quarts and gallons.
Quite a savings at $10.00 a quart.
http://www.jalopyjournal.com/forum/s...ghlight=por+15
