por 15
POR-15 is a "paint" that is designed to be a rust inhibitor. When the surface is prepped properly, it will never come off. As far as a "por-15 engine paint kit", I did not know they had one.
Why not just use an engine primer and paint?
The POR 15 engine paint has been around for a while. I used some on my RR and my son-in-law has it on his 56 GMC.
It flows on nicely and gives a good finish result. The kits which include cleaner, brush, mask etc. must be newer and I have'nt tried that however the paint itself is the same.
If you "GOOGLE" por 15 you will see all their products.
Never used it on a Mopar engine, But I have used POR-15 on my MG's, the engine paint stands up well on those little engines despite the heat they throw out, and constant oil and fuel leaks they are prone to.
I've also used POR-15 on a winch bumper which started out as bare rusted steel, that bumper lasted longer than the rest of the vehicle, and is still going strong on someone else's rig today!
My 2 cents is you can't go wrong with POR-15 if you apply it correctly!
Sorry to get off topic.
