por 15
Old Dec 18, 2009 | 01:21 PM
beep1969's Avatar
Junior Member
por 15
anyone tried the por-15 engine paint kit? i'll bee painting my 383 just wondering what the deal was with this paint
Old Dec 18, 2009 | 03:05 PM
mopar nate's Avatar
por 15 is a rust stopping paint i do believe
Old Dec 18, 2009 | 09:18 PM
what needs to be painted?
if it is just your block, i'd just spray it with the engine paint spray can
Old Dec 19, 2009 | 03:12 AM
POR-15 is a "paint" that is designed to be a rust inhibitor. When the surface is prepped properly, it will never come off. As far as a "por-15 engine paint kit", I did not know they had one.
Why not just use an engine primer and paint?
Old Dec 19, 2009 | 06:06 AM
beep1969's Avatar
Junior Member
por-15
i guess they do make the paint for engines available in all the factory colors. it might be a new thing i'm not sure. i'll be painting the whole engine soon i'll post pics and my opinion
Old Dec 19, 2009 | 07:12 AM
rdrunner1974's Avatar
Thumbs up por 15
The POR 15 engine paint has been around for a while. I used some on my RR and my son-in-law has it on his 56 GMC.
It flows on nicely and gives a good finish result. The kits which include cleaner, brush, mask etc. must be newer and I have'nt tried that however the paint itself is the same.
If you "GOOGLE" por 15 you will see all their products.
Old Dec 19, 2009 | 03:17 PM
64fury's Avatar
Never used it on a Mopar engine, But I have used POR-15 on my MG's, the engine paint stands up well on those little engines despite the heat they throw out, and constant oil and fuel leaks they are prone to.
I've also used POR-15 on a winch bumper which started out as bare rusted steel, that bumper lasted longer than the rest of the vehicle, and is still going strong on someone else's rig today!
My 2 cents is you can't go wrong with POR-15 if you apply it correctly!
Old Dec 19, 2009 | 04:47 PM
old tired rebel's Avatar
I went to Auto Zone and got some high heat Primer(VHT) 1300-2000 heat range and engine paint it holds up well I did my intake in it.
Old Dec 20, 2009 | 06:59 AM
challenger's Avatar
good info on the POR-15 THANKS
Old Dec 22, 2009 | 07:01 PM
67gtxclone's Avatar
I think the POR actually stands for Paint Over Rust.
Old Dec 23, 2009 | 03:50 AM
I have a friend that used it on a D60 rear axle he was building for his CJ project. It stuck really well to a rusty axle that just had a wire wheel gone over it. I wouldn't use it on a frame or bumper that would see rocks though as it will peel off just like anything else. a brush on bedliner would be better cheaper and easier to fix on something like that.
Sorry to get off topic.
scotty
Jan 25, 2012 05:24 AM
67 GTX
Jun 1, 2011 07:08 PM
