Which power steering pump?
Old Sep 8, 2012 | 02:04 AM
cork1958's Avatar
Anybody know which power steering pump was most common in the 1966 Plymouth Satellite? Was it a Chrysler or Saginaw?
What's the easiest way to tell? One guy I talked to at the parts store said it should say right on the unit, but I'm not seeing anything. The cap on my pump does have a "S" on the top, is all I see.
Will probably have to drive car to parts store and have them compare pics of the unit, but thought I'd give a try here to at least see which was most common.
Thank you
Old Sep 8, 2012 | 08:59 AM
You should have the round potbelly one.
Old Sep 9, 2012 | 03:06 AM
cork1958's Avatar
What brand name is the pot belly one?
Went down to parts store quite a bit after posting above. Guy there said it's a Thompson power steering pump. Don't know where that name came from as the other 2 parts stores I called the day before said it either had a Chrysler or Saginaw.
None of the stores have what I need!
Time to do some more searching, I guess.
Old Sep 9, 2012 | 08:46 AM
You need this one and I found a rebuilt unit at O'Reillys.http://www.oreillyauto.com/site/c/de...2869&ppt=C0031
Old Sep 9, 2012 | 06:50 PM
cork1958's Avatar
That pump you linked to says it's for a 1968 Dodge Dart 270
V8 - 5.2L vin F 318ci - GAS.
As positive as your post sounds about that being the one I need, I have to ask, what makes you sure about the one you posted being the one I need?
When I enter my vehicles info, this is the one that comes up, http://www.oreillyauto.com/site/c/de...2869&ppt=C0031
Neither of those pumps have my engine size, 5.9L, 361ci, even listed under the compatibility section. The part number you linked to is, Part # 20-6115. The one listed for my engine is Part # : 20-6074
Now, as confused as ever, but at least have another place to check at tomorrow. Forgot about O'Reilly's. They even have a new store being built that is even closer than the other local one listed on their site.
Old Sep 9, 2012 | 08:24 PM
Same pump. 60's through late 60's used the potbelly pump. I only cheated and used the easy link for my car.
Old Sep 10, 2012 | 02:45 AM
cork1958's Avatar
I don't think I remember seeing if that pump you linked to had the Thompson pump or not though.
The one I linked to does have a Thompson pump as does the one on my car.
Appreciate the help very much!!
66Newport
Apr 22, 2013 04:43 PM
1968polara383
Jan 8, 2012 07:45 AM
elsmootho
Aug 17, 2010 03:18 AM
brucewon
Apr 11, 2010 08:49 AM
heminate
Aug 17, 2009 08:07 PM
