Power steering pump?
O.K. so I got the 440 in the 68 Coronet and 2 things..
1.) It turns over and over but does not want to start and I think I have that one figures out to where the timing is off...
2.) As I am cranking the motor over my steering wheel just started to turn over to the left by itself...I get the wheels straight and their it goes again when I crank on it.
Who know what can cause that?
At first I thought you meant the motor would turn over when you turned the steering wheel --Had to re-read it. Maybe someone with more experience could chime in. The only thing I could think of is this:
A) Is the steering linkage coming in contact with the motor?
B) Is the steering box or column coming in contact with exhaust manifold or header?
C) Do you have a broken motor mount?
There is a centering valve on top of the steering box/gear that needs to be adjusted. the valve is where the high pressure hose hooks to the box. 2 bolts and it slides dont have to move it much maybe 1/16" they are very sensitive.And is done with engine off, tighten the bolts before starting the engine..Bill
HemiMeech (08-18-2013)
Always learning, that's something I didn't think about!! Nice call
