Roller Rocker adustment help.....
Old Sep 18, 2009 | 06:48 PM
DUST360's Avatar
Junior Member
Exclamation Roller Rocker adustment help.....
I please need detailed info on how to set my adjustable roller rockers on my Mopar 408 smallblock. thx so much
Mopar or no car
Old Sep 19, 2009 | 04:39 AM
No Problem Man.... First you must find top dead center... Turn the engine until both rocker arms are loose on cylinder 1. Double check this by making sure your rotor button in the distributator is lined up with plug wire to cyl 1 (This is called checking the rotor phase).Then check the following cylinders:
Ex 4 8 Intake 2 7
Turn the engine 180 degrees.... Then adjust
Ex 3 6 Intake 1 8
Ex 5 7 Intake 3 4
Turn the engine 180 degrees..... Then adjust
Ex 1 2 Intake 5 6
You are done.... I bought a remote start button that clips on to the start relay that makes this much easier. After you do this a time or two its not that big a deal. I have a plastic card that I carry in my wallet that has the sequence for the valve adjustment.. Hope this helps.... There is another way to adjust valves by adjusting the intake by the position of the ex and vice versa but this works best for me....
Old Sep 20, 2009 | 05:32 PM
OutlawCuda's Avatar
Senior Member
Lash Info for your firewall
Thought you might like this for your firewall. 1997 I bought this for my Cuda.
Attached Thumbnails Roller Rocker adustment help.....-blue-point-237.jpg   Roller Rocker adustment help.....-blue-point-240.jpg
goldenpistol
Apr 28, 2013 04:26 PM
Imfast101
20
Mar 30, 2012 09:32 PM
69POLARA383
Mar 29, 2012 08:59 AM
69POLARA383
Sep 24, 2010 11:29 PM
norcalmopar
Aug 6, 2010 03:51 PM
