Spark Plug thread issues
Old Feb 3, 2017 | 07:09 PM
motasupra's Avatar
Lightbulb Spark Plug thread issues
OK when pulling spark plugs one was not coming out easy. Then when I tried to put a new one back no go. I was freaking out thinking the head was coming off no matter what.
Power Built 14mm x 1.25 back tap. Sounds dumb if you ask me but I was desperately needing an answer so I ordered one. I used assembly lube and threaded from the inside out about 4 times by hand. I cleaned the tap out after every pass with carb cleaner. Then the last two passes it was fully expanded with anti- seize. The new spark plug went in easy by hand and I feel that there's plenty of threads. Edelbrock performer heads.
Anyway I feel this is a good cheap tool.
Old Feb 3, 2017 | 07:14 PM
motasupra's Avatar
Oh yeah also I think all the debris came out in the lube instead of into the motor.
Old Feb 4, 2017 | 01:10 AM
If you have further problems Use a timecert and locktite. Grease the tap and drill.
Old Feb 4, 2017 | 12:07 PM
I like to use Anti-Seize.... But thats just my 2 cents....
https://www.permatex.com/products/lu...e-lubricant-2/
Old Feb 4, 2017 | 06:30 PM
I like to use Anti-Seize.... But thats just my 2/[/url]
Slick *****, bahahahahahaha
Old Feb 11, 2017 | 09:36 AM
haha, oh boy.
FlaBoy68
Apr 13, 2015 11:12 AM
Nomadci
Jul 10, 2010 06:18 PM
H-Pattern
Jun 9, 2010 08:09 PM
May 17, 2010 08:32 PM
will d
Feb 13, 2010 06:33 AM
