still overheating
Old Sep 27, 2016 | 07:44 PM
peteski's Avatar
still overheating
changed thermostat to 180, changed hoses, added elec fans, both come on at pre set 190*, changed out OLD water pump to a hi flow water pump, installed new water temp guage....: thermostat opens at 180, fans kick on at 190. BUT i cant go for very long in town, seems still gets too hot ( 210 + ) and still spews... found rear freeze plug under starter now has a leak...
Any thoughts out there...? I have a 22" 4-row alum rad, 2 10" fans
Thanks in Advance for the feed back and advice
Old Sep 27, 2016 | 10:19 PM
Should have put the 26" rad in when you put the aluminum rad in !!! IT gets HOT in Lancaster.. Do you have the fan shroud installed ??
Old Sep 28, 2016 | 05:04 AM
Archer's Avatar
Pete -
How did you set up the electric fans?
Did you flush the system?
Old Sep 28, 2016 | 05:08 AM
peteski's Avatar
fans preset to come on at 190*, have 180 TS and it opens at 180, then both fans kick on at 190 fans . I cant go anymore distance than a few miles out in town and back
Old Sep 28, 2016 | 05:09 AM
peteski's Avatar
yes flushed the sys, i had to take to shop to replace a freeze plug that started to leak
Old Sep 28, 2016 | 05:10 AM
peteski's Avatar
Again, Thanks in Advance for all of your advice
Old Sep 28, 2016 | 08:33 AM
Drag Pak's Avatar
Where do you have the timing set to? The timing being too retarded/late will cause overheating!
Old Sep 28, 2016 | 08:18 PM
All great points....Also have it tested for a head gasket problem...
Old Oct 15, 2016 | 06:12 AM
Magoo's Avatar
Pulleys
Are You under driving the water pump ? -- The crank pulley should be larger than the water pump pulley to cool properly. -- Just another thought.
53cranbrook
Jan 11, 2013 06:31 AM
metalhead
Aug 23, 2010 03:24 PM
jar84203
Jun 18, 2009 05:31 PM
outdoors724
Feb 8, 2009 05:16 PM
Mopar-4-life01
Jun 15, 2008 03:05 AM
