switch
Old Dec 29, 2012 | 06:31 PM
willysman69's Avatar
switch
ok I got my 340 running in my 69 dart but I cant start it by my switch. I have power to the coil when I turn the switch on but I loose power when it turns over. Do I need to tie the IGN 1 wire and the IGN 2 wire together any help appreciated thanks
Old Dec 29, 2012 | 06:41 PM
Chryco Psycho's Avatar
It depends what Ign system you running , but with MSD for example needs to have both the Blue & brown wires tied together or the MSD is not powered when you turn the key to start , the factory system doesn't need to be tied together
Old Dec 29, 2012 | 08:13 PM
Well the factory system IS tied together in a way
Mopar systems have 3 separate contacts having to do with the engine in the ignition switch.
1--"Ignition run" or "IGN 1" traditionally dark blue, goes to the instrument cluster for the gauges and warning lamps, and through the bulkhead to power the ignition and regulator, and alternator field on 70/ later cars, electric choke if used. HOT ONLY in "run."
2--"Bypass", or "IGN 2" traditionally brown goes from a contact in the switch, through the bulkhead and (factory) to the coil+ side of the ballast resistor. Feeds good hot juice to ignition during "start."
3--"Start" hot only in "start" traditionally yellow, goes from a separate contact on the switch, through the bulkhead, and to one of the "push on" terminals of the start relay
BASICALLY when you tie the "run" and "bypass" (blue and brown) together, you are simply eliminating the coil resistor.
Arbiter343GS
Oct 31, 2011 08:44 AM
dorseyh
Aug 22, 2009 10:27 PM
hemihead
Mar 18, 2008 03:23 PM
Popeye
Jan 5, 2007 07:45 PM
Popeye
Dec 16, 2006 03:24 PM
