tire pressure vs temp calculted
Too many variables. One reason N2 is used nowadays is to eliminate moisture, which is affected different than dry air or N2
The size of the tires, type, bias, radial, steel, etc, even the type of wheel. Aluminum wheels will conduct more heat away from the tire than do steel, so even the width of the wheel comes into play.
Only way I'd know is to make a few measurements at different temperatures so you can check it. I mean, if there was an easy way, would racers need pressure gauges?
74Runneer
01-11-2015 02:20 PM
