tire pressure vs temp calculted
Old Feb 2, 2014 | 10:19 AM
moe7404's Avatar
if know the what the temp is going to change to can i know what the pressure will be?
Old Feb 2, 2014 | 10:40 AM
Too many variables. One reason N2 is used nowadays is to eliminate moisture, which is affected different than dry air or N2
The size of the tires, type, bias, radial, steel, etc, even the type of wheel. Aluminum wheels will conduct more heat away from the tire than do steel, so even the width of the wheel comes into play.
Only way I'd know is to make a few measurements at different temperatures so you can check it. I mean, if there was an easy way, would racers need pressure gauges?
74Runneer
Jan 11, 2015 01:20 PM
74charger
Oct 26, 2011 05:31 PM
71_Duster
Apr 29, 2010 07:34 PM
joe440
Jun 30, 2009 08:34 AM
JLanzino
May 11, 2009 04:00 PM
