torqueflite help
torqueflite help
ok so im thinking that my torqueflite 904 is toast, my question is if i get a "newer" 904 or 727 one can i just swap it in or is there only some 904/727s that will work in my 78 Chrysler cordoba with a 360?
thanks a lot
thanks a lot
As long as you get the small block case, then yes it'll work.
But you'll need to get a different driveshaft or have yours cut to fit. IIRC, then 727's require a SHORTER driveshaft, b/c they tailshaft is longer then a 904.
hckrphil
05-16-2014 05:23 PM
78PW400ci
05-03-2010 10:30 PM
hubcap
05-28-2008 05:24 PM
