torqueflite help
Old May 19, 2009 | 01:44 PM
78cordoba's Avatar
Member
torqueflite help
ok so im thinking that my torqueflite 904 is toast, my question is if i get a "newer" 904 or 727 one can i just swap it in or is there only some 904/727s that will work in my 78 Chrysler cordoba with a 360?
thanks a lot
Old May 19, 2009 | 09:15 PM
blue 68 gts's Avatar
As long as you get the small block case, then yes it'll work.
But you'll need to get a different driveshaft or have yours cut to fit. IIRC, then 727's require a SHORTER driveshaft, b/c they tailshaft is longer then a 904.
Old May 28, 2009 | 07:56 PM
78cordoba's Avatar
Member
i think that i am gonig to be getting a 904 out of a dart or satellite it will work right?
Old May 29, 2009 | 03:48 AM
As long as there is a small block V8 in front of it, it should bolt right up.
Old May 29, 2009 | 08:29 PM
78cordoba's Avatar
Member
is it going to matter if the one i have now has a lock up converter and the "newer" one doesn't?
hckrphil
May 16, 2014 05:23 PM
zrwhat
Mar 4, 2011 07:22 PM
78PW400ci
May 3, 2010 10:30 PM
hubcap
May 28, 2008 05:24 PM
hubcap
May 6, 2008 06:26 PM
