Very slow take off
Old Jan 28, 2012 | 11:29 AM
Valex9499's Avatar
Very slow take off
I bought a 66 Barracuda a few months ago. The previous owner swapped out the 4-speed tranny and put an automatic 3-speed in it. Do you think that would affect the acceleration of the car? Also the gears are stock.
Valentin
Old Jan 28, 2012 | 03:42 PM
HEMI-ITIS's Avatar
Could be the wrong converter for your combo.
Old Jan 28, 2012 | 04:05 PM
PK1's Avatar
PK1
Affect it in what way?
Old Jan 28, 2012 | 04:07 PM
Can you give some more info on your powertrain.
Old Jan 28, 2012 | 04:41 PM
Check and make sure you are getting full throttle. also check the throttle pressure linkage - make sure it is hooked up and adjusted properly.
Old Jan 28, 2012 | 08:15 PM
HEMI-ITIS's Avatar
GOOD point!!
Old Jan 28, 2012 | 11:53 PM
Quickest way to kill a TF trans is to have the throttle pressure disconnected.
Forgot to mention. Make sure the brakes are not dragging
Old Jan 29, 2012 | 07:24 AM
Valex9499's Avatar
Thanks for the tips. I will check throttle pressure linkage. Thing is after it gets moving it picks up, so it does get full throttle.
Old Jan 29, 2012 | 07:26 AM
Valex9499's Avatar
The engine is a 273 and the tranny is a 3-speed 904. I am not sure about the diff. but that is stock. So the gears are what came with the car.
Old Jan 29, 2012 | 08:37 AM
After checking your linkage you could jack up the car and turn all tires by hand in Park and N or find a downhill engine off out of Park then feel and listen to the car. A good coast with no rubbing or scraping noises will eliminate alot very easily.
Old Feb 7, 2012 | 03:37 PM
273 is very under powered.. Don't expect too much
Old Feb 7, 2012 | 06:14 PM
Silverick's Avatar
Right!
I put a '69 383 Magnum in a '68 Fury and with 3.23 gears..... it wasn't a tire burner. But, from 20mph, in low.... she'd jump pretty good!
Old Feb 7, 2012 | 06:57 PM
Archer's Avatar
V -
Is it just slow on the launch or is there a hesitation? Does it matter is the engine is cold or warm?
Doubleclutch
Nov 3, 2014 06:38 AM
moe7404
Aug 5, 2013 05:52 AM
palerider508
Jun 23, 2011 03:09 AM
67gtxclone
May 30, 2010 05:05 PM
67gtxclone
May 30, 2010 04:10 PM
