warm runs rough
Old Apr 20, 2009 | 02:30 PM
sgp7679's Avatar
Question warm runs rough
When i first start my car for the day it runs fine for a while, when it warms up after a while it starts to die when you put it in gear. in park or neutral it idles fine, but when you engage in gear, the engine is kinds shakey and will die unless you gas it. Once you get going its fine though, but if you let off the gas at a stop, it usually dies. what could it be?
Old Apr 20, 2009 | 02:37 PM
theomahamoparguy's Avatar
Needle and seat in the carb.first guess
Old Apr 20, 2009 | 02:48 PM
sgp7679's Avatar
well it has a brand new rebuilt carb.
Old Apr 20, 2009 | 04:00 PM
craveman's Avatar
Senior Member
things can still be screwed up on rebuilds. also check to make sure your choke is opening up after a few mins.
Old Apr 20, 2009 | 04:07 PM
craveman's Avatar
Senior Member
thats if its an electric choke
Old Apr 20, 2009 | 04:25 PM
sgp7679's Avatar
no its not elec. choke, im thinking its the carb, ive never adjusted it and i know it needs adjustment, im no good at adjusting carbs, any tips on how to?
Old Apr 20, 2009 | 04:30 PM
what kind of carb is it?
Old Apr 20, 2009 | 04:36 PM
sgp7679's Avatar
carter 2 bbl
Old Apr 20, 2009 | 06:24 PM
carter 2 bbl
try turning the two idle mixture screws [near the front bottom] counterclockwise 1 1/2 turns, see what that does.
Old Apr 20, 2009 | 06:31 PM
sgp7679's Avatar
i know this is a dumb ? but is 1 turn a complete turn, example, when your looking at the screwdriver slot, and its flat and you turn it till its flat again, is that one turn or a half turn? or is it where its flat and you turn it till its flat then on the next flat revolution a complete turn?
Old Apr 20, 2009 | 06:53 PM
craveman's Avatar
Senior Member
a complete 360 degree rotation.
Old Apr 20, 2009 | 07:17 PM
MarkyMark12345's Avatar
Member
Who rebuilt the carb? I've never worked on a carb for a car, but I've rebuilt many motorcycle carbs. I once pinched the vacume piston when reassembling and it tore, leading to symptoms similar to what you are describing. Like I said, that was a motorcycle carb, but might be something to look at if easier troubleshooting steps don't work.
Old Apr 20, 2009 | 07:34 PM
sgp7679's Avatar
well i bought it new (rebuilt).
Old Apr 20, 2009 | 07:45 PM
Member
Gotcha. Well I would try adjusting the idle mixture like Omaha said and see if that fixes the problem
Old Apr 21, 2009 | 04:38 PM
agreed
Old Apr 21, 2009 | 05:02 PM
hey sgp7679
how is your carb adjusting going?
Old Apr 21, 2009 | 05:10 PM
Member
FYI I edited my earlier post. It was the vacuum piston I tore, not the diaphragm
Old Apr 21, 2009 | 05:51 PM
sgp7679's Avatar
well i adjusted the screws 1 1/2 turns out. I drove it around for a while and turned it off and it wasnt doing it. Now I need to get a tach and adjust my idle, it sounds kind of high. Sometimes it still runs a little rough but hasnt died. Well it did die once, I had a/c on full blast and was coming in driveway real slow and it died.
Old Apr 22, 2009 | 03:47 PM
make sure your idle isn't too high
it isnt good for auto's to have that
Old Apr 22, 2009 | 03:55 PM
scotts74birds's Avatar
Does your car have and idle/ac solenoid? Its a small device with a plunger that that is powered when the ac is on. Its job is to hold the throttle just off of idle to compensate for the compressor drag.
Old Apr 22, 2009 | 05:52 PM
sgp7679's Avatar
im not sure if it has ac idler, is it on the carb? also, on the back of the carb. where you hook up the choke vacuum, there is an extra spot to hook up another line. It sucks in air. My original carb didnt have this. I just plugged it up and its running okay. Any idea what that does? I tried to get pics but camera isnt working.
Old Apr 22, 2009 | 06:12 PM
Plugging any unused vacuum ports is a Good thing. Couldn't tell you what all the vacuum ports are for on that car, electrical is my forte. Right now carbs are making my life miserable. I've got a Mikuni on my Harley, set it 10 yrs ago and havent had to touch it yet. Wish they made 4 barrels!! Like I said, an idle/ac solenoid would stop the throttle from going to its idle position, but only slightly. Its like putting an extra turn in on your idle stop screw, but only when the a/c is on. Anyone else know if his car would have one of these? What do the old ones look like?
Old Apr 22, 2009 | 07:34 PM
  #24
sgp7679's Avatar
ill try to get some pics tomorrow, I think that I do have that ac idler.
Old Apr 25, 2009 | 11:44 AM
  #25
pics?
gyates93
Mar 9, 2023 02:36 PM
jonnyb
Oct 2, 2012 06:55 PM
77Adventurer
13
Aug 29, 2012 10:23 AM
Barfly
Apr 12, 2011 03:43 PM
DartConvertible
Mar 17, 2008 05:22 PM
