weird pops
when your going around 50-60 in my 03 dodge ram it feels like its popping or something. it dosent make any sounds just jerks you in little pops.The truck has 200000 miles. COuld it be the tranny or motor? It does this as you accelerate, when you going slower or faster than 50-60 its fine.
Guest
Posts: n/a
try cleaning the throttle body completely including the throttle position sensor and iac. they are pretty sensitive, and the truck will run crappy if they are dirty. also check if you are throwing any codes. not sure if this is an option in the 03's - if you put the key in and turn it back and forth from off to the on position, on the 5th on position your odometer will read "done" and give you any codes that are present.
There may be a little flat spot in your TPS, but I would first go with a general tune up and go from there. The usual, plugs, wires and see if the pop is still there. Keep us posted, we'll help if we can.
Most likely is but I have a friend a few towns over who's father has an 03 Ram 1500 2wd with a 3.7 and manual, hence why I asked about motor and tranny.
Plus John has a 1500 with a 4.7 and manual as well.
well the first day the truck wasnt running so good again and the check engine light came on, i checked the engine and there was a hose i forgot to connect, reconnected it and reset the comp. and it is running good now, but now it feels like its idling too low and dies sometimes when you get off the gas to slow down.
