weird pops
Old Mar 29, 2009 | 11:04 AM
sgp7679's Avatar
Question weird pops
when your going around 50-60 in my 03 dodge ram it feels like its popping or something. it dosent make any sounds just jerks you in little pops.The truck has 200000 miles. COuld it be the tranny or motor? It does this as you accelerate, when you going slower or faster than 50-60 its fine.
Old Mar 29, 2009 | 04:16 PM
Polaradude's Avatar
I could be alot of things, is the pop a noise or is it moving you in the seat. That will narrow it down a little.
Old Mar 29, 2009 | 08:13 PM
sgp7679's Avatar
no noise but you feel it jerking you in little pop like feelings. best i can explain it.also its only when you accelerate in the 50-60 area.
Old Mar 29, 2009 | 08:47 PM
theomahamoparguy's Avatar
Is it a 4-wheel drive?
Old Mar 29, 2009 | 09:45 PM
sgp7679's Avatar
no 2wd 1500
Old Mar 29, 2009 | 10:02 PM
My theory out the window {4-wheel drive problems}Best guess;ignition related.
Its a really weird sounding problem!
Old Mar 30, 2009 | 12:04 AM
johnthegoalie's Avatar
thinkin with me dipstick
try cleaning the throttle body completely including the throttle position sensor and iac. they are pretty sensitive, and the truck will run crappy if they are dirty. also check if you are throwing any codes. not sure if this is an option in the 03's - if you put the key in and turn it back and forth from off to the on position, on the 5th on position your odometer will read "done" and give you any codes that are present.
Old Mar 30, 2009 | 01:52 AM
Polaradude's Avatar
There may be a little flat spot in your TPS, but I would first go with a general tune up and go from there. The usual, plugs, wires and see if the pop is still there. Keep us posted, we'll help if we can.
Old Mar 30, 2009 | 02:23 AM
What motor do you have in it? Tranny (auto or manual)?
Old Mar 30, 2009 | 02:37 AM
Polaradude's Avatar
What do ya bet it's an automatic Tim ?
Old Mar 30, 2009 | 03:12 AM
Most likely is but I have a friend a few towns over who's father has an 03 Ram 1500 2wd with a 3.7 and manual, hence why I asked about motor and tranny.
Plus John has a 1500 with a 4.7 and manual as well.
Old Mar 30, 2009 | 05:33 AM
sgp7679's Avatar
its a 4.7 auto. its gonna be getting a tune up soon so ill see what happens.
Old Mar 30, 2009 | 07:17 AM
Clean the TB, IAC, and TPS really good.
have you noticed a difference in your gas milage since this started happening? Or a random skipping?
Old Mar 30, 2009 | 08:01 AM
after the truck is all warmed up, at stop lights and such - do you notice a rough idle at all, even slight?
Old Mar 30, 2009 | 01:43 PM
sgp7679's Avatar
nope, good idle, it runs perfect besides the jitters in 50-60 range. gas mpg is the same, hasnt changed.
Old Mar 30, 2009 | 02:25 PM
Polaradude's Avatar
How's the tranny fluid level,colour,smell ?
Old Mar 30, 2009 | 04:31 PM
sgp7679's Avatar
ill check that
Old Apr 6, 2009 | 05:21 PM
sgp7679's Avatar
it was the plugs. all good now
Old Apr 6, 2009 | 08:03 PM
which engine do you have? i have the 4.7 - i found the best results both in running and mpg with the stock oem champions
Old Apr 11, 2009 | 02:31 PM
sgp7679's Avatar
well the first day the truck wasnt running so good again and the check engine light came on, i checked the engine and there was a hose i forgot to connect, reconnected it and reset the comp. and it is running good now, but now it feels like its idling too low and dies sometimes when you get off the gas to slow down.
Old Apr 11, 2009 | 02:40 PM
Polaradude's Avatar
Is it running rich ? Gas smell at the tailpipe ?
D200powerwagon
Feb 24, 2014 05:14 AM
ssdart225
Feb 25, 2011 05:18 PM
samuelcosmo76
Jan 9, 2010 07:43 AM
sgp7679
May 13, 2009 02:52 PM
youngtwister
Dec 27, 2008 03:55 PM
