What horsepower would a 440 be putting out
Old Nov 18, 2009 | 06:56 PM
Hibred's Avatar
Just wondering what kind of horspower an early 70's 440 would be putting out, its been done up 30 over, Edelbrock intake and 650 carb, mild street cam, original high performance exhaust manifolds with 2 1/2" exhaust and catbacks, electric fuel pump and regulator, MSD Ignition and high tension wires, have no idea what power this is putting out, its in a 64 Plymouth Sport Fury i just bought, hope you fellas can give me an idea, thanks.
Old Nov 18, 2009 | 07:02 PM
scotts74birds's Avatar
Here you go! http://www.compcams.com/camquest/default.asp Do the free download. It is pretty accurate, but not exact. Fun to play "what if I did this" with. Should give you a good idea of what does what, and find the item that may be holding you back. Welcome. Scotty
Old Nov 18, 2009 | 07:11 PM
650 is too small, my opinion. if you want original manifolds, fine. No need for electric fuel pump. I've read tests, and wires are wires, $30-100, they will run the same. Only difference will be heat resistance. I like the car! Plug in a 750 vac secondary and look for an increase in the power in the camquest. What trans, rear gears, usage and goals?
Old Nov 18, 2009 | 09:27 PM
theomahamoparguy's Avatar
guess 375 to 410 if it is tuned well and has good cranking pressure.
It's all about the combination of parts that you put together.
Old Nov 19, 2009 | 03:50 AM
Originally Posted by Hibred
Edelbrock intake and 650 carb, electric fuel pump and regulator
Edelbrock carbs like low fuel pressure as in 3-5 PSI. FYI
Old Nov 19, 2009 | 10:55 AM
Hibred's Avatar
Sorry the carb is a 750, not a 650 as i had posted, thanks for all the replies, nice to know there are lots of you guys out there helping. I just bought the 64 Plymouth Sport Fury and know very little about it, will try and post some pictures of it soon, again thanks.
Old Nov 19, 2009 | 02:00 PM
i would say, depending on the cam, that you have approximately 400 hp at the flywheel
Old Nov 19, 2009 | 02:12 PM
Hibred's Avatar
It really seems to have more then a "mild cam", thats what i was told when i bought it but the cam definately is noticeable when its running, something you can hear so i feel its more then just the mild cam. Thanks for all replies.
Old Nov 19, 2009 | 09:09 PM
62Furious's Avatar
Thumbs up
Hibred i can't waite to see your pics because I am a pre 65 mopar guy, and with a 440 it should move down the road pretty good
bremereric
Nov 28, 2015 03:57 PM
68 Fury
Feb 20, 2013 06:01 PM
eyecanwalk
Nov 10, 2011 03:28 PM
bremereric
May 8, 2011 08:31 AM
tmcdowell66
Nov 30, 2008 03:12 PM
