Wheels for a 69 Dart
Hi,
I'm new to Mopars and I'm not sure what's the lug spacing that I should look for for my 69 Dart. I want to change the stock wheels and I'm not sure if I want to go aftermarket or maybe get some late model wheels and use those instead. Does anybody knows which late model wheels will fit my Dart?
TKS
TKS
You need to be careful. Your '69 may have the 4 inch bolt circle. These are hard to find wheels, good luck. I changed my rear to an 8.75 and that gave me 4 1/2 out back but I still have the 4 inch up front.
TKS,
How do I measure the spacing? I want to be sure.
If It turns out to be a 4, from where can I get the rear end and front end to make it a 4.5? What donor car shouls I look for?
hi fp
to measure the bolt circle the bolt directly across from the other will give you the measurement either 5 on 4 or 5 on 4 and a half any 73 and a-body will give you a 4.5 bolt circle [ 73 disc brake car 4.5 drum would be 4.] as for rear end a 8.75 a-body rear end will work you'll just have to get aftermarket axles with a 4.5 b.c or you could find a 73 and up 8.25 a-body rear end
goodluck
Terry
goodluck
Terry
ThomasNieman710
06-07-2013 04:47 AM
